Technical FORD TRANSMISSION SWAP
Discussion in 'The Hokey Ass Message Board' started by MYROAN, Sep 1, 2019.
  1. MYROAN
    MYROAN
    CAN I SWAP A 1963 FORDAMATIC TRANSMISSION WITH A 1966 FORDAMATIC TRANSMISSION?
  2. squirrel
    Maybe, maybe not. Ford used a lot of different bellhousing bolt patterns, and there are other things that might be different. So, to answer your question, we need to know exactly what Ford-O-Matic you have now, and which one you want to swap for. Including what engine each was originally behind.
    town sedan and Truckdoctor Andy like this.
  3. 51504bat
    51504bat
    Small block Ford's changed bell housing from 5 to 6 bolts between '64 and '65 if IIRC.
  4. MYROAN
    MYROAN
    THE FORDAMATIC 3SPEED THAT IS IN NOW IS HOODED TO A 390 CID FORD AND THE 66 COMES FROM ANOTHER GALAXIE ALONG WITH THE BELL HOUSING AND TORQUE CONVERTER
  5. squirrel
    The 63 should have the Cruise-O-Matic, and the 1961-64 versions of it are the same.
    The 66 probably has the C-6 transmission.
  6. MYROAN
    MYROAN
    SO THE BELL HOUSING WILL NOT FIT A 63 390 MOTER ?
  7. MYROAN
    MYROAN
    THE MOTOR I HAVE IS A 390 BIG BLOCK WOULD THE BELL HOUSING FROM THE 66 FIT?
  8. squirrel
    If it's from a car that came with a 390, then it should fit the engine. As for the mount, driveshaft, linkage, etc I don't remember enough to know if it's a bolt in, or if you'll have to change things.
  9. MYROAN
    MYROAN
    THANKS THAT ANSWERS MOST OF WHAT I NEED TO KNOW, I'M, SURE THE 66 TRANS IS LONGER THAT THE 63 SO I WILL HAVE TO HAVE A DRIVE SHAFT BUILT, UNLESS THE TAIL SHAFT WOULD SWAP????
  10. MYROAN
    MYROAN
  11. MeanGene427
    MeanGene427
    from Napa
    In '66, the 390 cars were usually still equipped with the Cruiso, and the 428 cars got the C6- and the '66 C6 still had the "green dot" shifting pattern. In '67 the C6 got a new valve body with the new PRND21 pattern
    Ewog70 and town sedan like this.
  12. squirrel
    That's probably a good thing. Best thing to do is to spend a while looking at both transmissions, and see if they look the same, or different, and what the differences are.
    If you're asking the question, then you probably have access to both transmissions, eh? Take a look, do some measuring, etc. Take your time at it.
  13. MYROAN
    MYROAN
    THAT GOOD ADVICE AND YES I DO HAVE BOTH TRANSMISSIONS I AQUIRED THE 66 YESTERDAY ALONG WITH THE BELL HOUSING AND CONVERTER SO TIME WILL TELL, THANKS FOR YOUR INPUT
  14. gto66pont
    gto66pont
    If the heel comes off the trans like a stick shift it’s a cruise o Matic one piece case is a c 6. Small case early trams is a ford o match for small motor cars
  15. town sedan
    town sedan
    C6 -an aluminum case with the bell housing cast as part of the transmission case. At least 3 different bolt patterns I can think of. FE, 302 V8/300 L6, and one for the 351M / 400 V8 & 460 style engines.
    On Cruise-O & Ford-O automatics typically you'll find a cast iron transmission body and a removable bell housing. All the bells I've seen have been aluminum.
    Good luck with your project.
    -Dave
