Projects Ford TwinT straight 8 build
Discussion in 'Traditional Hot Rods' started by Blackbob, Mar 10, 2020.
  1. Commodoreswab
    Commodoreswab
    from West TN
    I remember first hearing about the 8 t in the vintage Ford, recently I found it at the speedster reunion. IMG_2023-06-23-12-36-37-953.jpg
    rod1, 41 GMC K-18, Blackbob and 4 others like this.
  2. Blackbob
    Blackbob
    Hi Folks, sorry it's been a while. Life sorta got complicated about 3 years ago and I had to sell up a lot of my stuff. The Gin Runner went north to a friend and I put the TwinT parts in storage, I've been back in full time work at the zoo ever since. Fixing up a '56 Landrover 86" there in my breaks which should be back on (and off) the road soon then I plan to pull the TwinT back out and work on it at my workplace. Hopefully, there will be some updates soon!
    tractorguy, cactus1, Outback and 8 others like this.
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    Saw this twin T in a video on another HAMB thread, think the event was in the UK
    rod1, Outback, Deutscher and 4 others like this.
  4. brading
    brading
    Think you are right, pretty sure that is Pendine Sands in Wales.
  5. Blackbob
    Blackbob
  6. Blackbob
    Blackbob
    OK folks, just a bit of an update.. Ive been rummaging through the parts stash over the past week and have made some decisions. As the two T motors that I have set aside for the TwinT are pretty much rebuilt and just need a freshen up and also both 1926 motors, I think I have a fighting chance to get the power plant together and running in 2026 and possibly built into a simple rolling ch***is. I have got a ch***is lined up and have axles available too so not an awful lot to find or make. So with that in mind I pulled the arp off the pile at work and got the two motors on a pallet ready to move and also dug out the 1/2 built extended oil pan .. Ive started to build a timber bench to support the oil pan at a comfortable height at the back of our works metalwork shed and hope to mount the oil pan onto it early next week... let the games begin!!
    The '28 Chev motors need considerably more work and thought so will follow once the TwinT is sorted.
    cactus1, rod1, Outback and 8 others like this.
  7. Outback
    Outback
    from NE Vic
    So excited you are back on this!
    Blackbob likes this.
  8. RodStRace
    RodStRace
    Blackbob and warhorseracing like this.
  9. Blackbob
    Blackbob
    This sketch is an idea I’ve been playing with in my head for a while is based on the Gerber special but splaying both sides of the ch***is rails and using a pair of 1/4 elliptic springs. It would help lower and declutter the rear end and also let me get the two seats down between the ch***is rails
    282doorUK, Carter and rwrj like this.
  10. rwrj
    rwrj
    from SW Ga
    I like that idea a lot. A two-engined, two-seated Gerber. Holy smokes. Nice job on the sketch, as well.
    tractorguy, Carter and Blackbob like this.
  11. RodStRace
    RodStRace
    I would be concerned with the rear springs not having enough of a solid support from those frame extensions. No side to side strength shown (rear crossmember). Perhaps something rising up so the vertical was doubled? That would get in the way of humans, though.
    If the extensions were flexible, the spring rate and control would be off. If they were stiff, the mounts would be under huge stress.
    Just cons***utive critique, hope you can get it working.
    rwrj and Blackbob like this.
  12. Blackbob
    Blackbob
    Yes that does make sense, perhaps a floor welded in under seats and a structural U shaped torque tube cover to stiffen it all up
  13. Blackbob
    Blackbob
    This is how the Mad Scotsman in Oz did it on his Gerber IMG_5723.jpeg IMG_5722.jpeg
  14. AmishMike
    AmishMike
    ^^^. Love those pictures. Thanks for posting. Love the leather elbow guard on left
  15. rwrj
    rwrj
    from SW Ga
    The crossmember under the driver’s thighs is a creative solution.
