Ford Valve Cover Adapters?
Discussion in 'The Hokey Ass Message Board' started by tigerShark, Dec 18, 2008.
  1. tigerShark
    tigerShark
    from Tampa Bay
    ive been searching for valve covers for my 460 for some time and i havent seen anything im too crazy about. however, the FE and Y-block valve covers are very attractive.
    does anyone make an adapter to bolt FE or Y-block valve covers to 429 or 460 heads?
  2. 62rebel
    62rebel
    i don't have examples of a 460 to check for dimensions, but the FE cover is very deep and should clear most any valvetrain, if it spans the length correctly. if i were doing this, i'd try one or two methods that might work;
    1. section the existing 460 covers down to get a good flange to mount the upper sections of FE covers, sectioned to fit. this might entail using 2 complete sets of FE covers, i don't know as i haven't got measurements to compare. OR.....
    2. get a machinist to fab up a set of aluminum spacers that have the 460 bolt pattern to attach them to the head, and a FE pattern to attch the valve covers. again, i don't have measurements to see if there's VERY obvious differences to contend with!
    but what the hell, if folks can put Olds Rocket covers on SBC's i don't see what they could say about a 460 with "THUNDERBIRD" covers on it!
  3. choppintops
    choppintops
    Another thing maybe, take a pair of stamped stock 460 ones, cut the logo or whatever out of a pair you like, cut out the same size in your 460s and weld in the other tops.
  4. Just Gary
    Just Gary
  5. bluebolt
    bluebolt
    from Benton LA
    The 429 is a lot bigger, I doubt if the FE valve cover will fit it. The MEL 430-462 valve covers might be closer. What look are you going for?
  6. tigerShark
    tigerShark
    from Tampa Bay
    i want a more nostalgic look. like some finned covers.
  7. bluebolt
    bluebolt
    from Benton LA
    How about these Blue Thunder covers? You have to get them from Blue Thunder dealers, they do not sell direct. Survival Motorsports is a Blue Thunder dealer.
  8. Speedmaven
    Speedmaven
    I have seen several sets of adapters to put BBC covers on a 460. If I did that, I would use an old set of M/Ts on the 460. The BBC M/T covers look a whole lot better than the 460 ones...There were a couple sets on eB last week, made by the Ansen guy who sells all those nostalgia covers. By the way, 460 covers are 2 or 3 inches longer and almost an inch wider than FE covers.. Y block covers are completely out of the question, being even shorter than 289-302 covers.
  9. Henry Floored
    Henry Floored
