Technical FORD VIN
Discussion in 'The Hokey Ass Message Board' started by normanpitkin, Jun 14, 2021.
Tags:
  1. normanpitkin
    normanpitkin
    from london
    hi ,Im trying to decode this ford vin but failing miserably ! Any experts out there? Its a 59 Ford Galaxie Sunliner. B4409A3D-5C44-4B16-AF45-4866292263DF_1_201_a.jpeg B4409A3D-5C44-4B16-AF45-4866292263DF_1_201_a.jpeg B4409A3D-5C44-4B16-AF45-4866292263DF_1_201_a.jpeg
  2. the-rodster
    the-rodster
    That is not original to the car.
    Rich
  3. 51504bat
    51504bat
    What @the-rodster said. In '59 the numbers weren't referred to as vin's. That came later IIRC. Regardless something seems hokey. If that is the only number plate on the car I'd stay clear of it.
    warhorseracing and gimpyshotrods like this.
  4. the-rodster
    the-rodster
  5. F-ONE
    F-ONE
    from Alabama
    It's an English car, as in the Queen, England.
    The VIN very well could be different on such a car. I for one know nothing on VINs, import, export and so on. I'm not qualified to have an opinion on the Ps and Qs of VINs pertaining to English cars. It could be right as rain.
    B9....1959
  6. oldolds
    oldolds
  7. squirrel
    B 332 V8
    9 1959
    C Chester PA ***embly plant
    G Custom 300 sedan
    The rest is the serial number.
    As mentioned, the tag is not original, although it could have the original number. We can only guess.
  8. RmK57
    RmK57
    Could be the car was re-registered with a new vin tag for some reason. You could check the consecutive numbers on the frame rail and see if they match with that plate.
    Hnstray and olscrounger like this.
  9. olscrounger
    olscrounger
    Have seen a few with tags similar to that--I p***!
    lothiandon1940 likes this.
  10. lothiandon1940
    lothiandon1940
    .............Sounds fishy to me. A Galaxie 500 Sunliner with a Custom 300 Sedan vin. There's been some shady stuff in its' past somewhere. Be scared, be very scared.:eek:
  11. normanpitkin
    normanpitkin
    from london
    im going to check on the frame rail! Car was restored in Florida in 2011 ,tag probably lost ,number copied wrongly from the frame rail i suspect!
  12. RmK57
    RmK57
    I think on the p***enger side, top of frame rail right below the firewall are the VIN#'s.
    If it checks out to be correct you can get a new data plate made with all the correct paint, rear axle, interior trim codes made from several sources.
    normanpitkin likes this.
  13. squirrel
    Convertible should have the fourth character as C
    I didn't catch that, sorry
  14. dan c
    dan c
    if you build an un***led car in missouri, you have to get it inspected by the highway patrol. if you p***, they affix a vin plate. maybe that's what this is?
    03GMCSonoma likes this.
  15. Mr48chev
    The number comes out just as Jim said above
    B9CG168565 - 1959 Ford VIN number breakdown - VINmagic.com
    1959 Ford!
    VIN: B9CG168565
    Engine Code B V8 332 ci OHV - 2V Carb. 225hp
    Production Year 9 1959
    ***embly Plant C Chester, PA
    Body Style G Custom / Custom 300 Tudor / Fordor
    Production Sequence 168565 168565
    Body swap onto a sedan frame using the sedan vin?
  16. Hotrodmyk
    Hotrodmyk
  17. Mr48chev
    59 Ford Vin tag.jpg Sounds like the "all restored" was all ***embled from parts using the frame and ***le from a sedan.
    The actual 59 Galaxy vin tag /id tag should look similar to this one.
    stillrunners and jimmy six like this.
  18. Budget36
    Budget36
    There was a recent thread about someone needing a VIN on a car that originally just had a s/n. In order to import it properly.
    This could be the same situation?
    Only thing I can add in Ca a plate can’t have a screw holding it on, I went through that when getting a PU inspected , one rivet had let go, the CHP guy said to “get that screw out of there “.
    stillrunners likes this.
  19. Looks like a tag bought on EBAY. I bet they bought a ***le also. My advice, RUN.
    Charlie Stephens
    jimmy six and lothiandon1940 like this.
  20. Mr48chev
    Too many red flags on that car for a guy to want to spend real money on it.
  21. normanpitkin
    normanpitkin
    from london
    Ive asked the questions ,lets see what the answers are!
  22. 51504bat
    51504bat
    A year or so ago I bought some Model A parts from a guy in Riverside, CA. He was selling complete Model A's to oversea buyers. I asked him how he handled the paperwork on a Model A where the engine number didn't match the frame number (which is hidden by the body as most know) He showed me a vin/ID plate similar to the one posted in the OP. He said he stamped the number from the pink slip/certificate of ***le on the plate and attached it to the door post. Never had an issue exporting that way. I just shook my head to myself, paid for my parts, and left.
  23. X38
    X38
    It says VIN Number. So that's vehicle identification number number. Factories don't do things like that.
  24. Sure they do....bogus VIN tag factories do. Automobile ***embly plants, no.
    gimpyshotrods likes this.
  25. normanpitkin
    normanpitkin
    from london
    Wait ! I just found this , it’s a 59 with 5500 original miles and the vin is. H9EG222480
    I’m confused !
  26. woodscaper
    woodscaper
    You mean there are two numbers/tags on the same car? Ouch.
  27. X38
    X38
    Just make sure you're not screwed.;)
    normanpitkin and lothiandon1940 like this.
  28. greybeard360
    greybeard360
    In Texas you can do a frame swap like that legally. You have to have a ***le for both vehicles. They will merge the vins in their system showing them as one vehicle. One gets built, the other has to be s****ped. If the car gets inspected and they run both vins they come back to the same ***le number after the merge.
  29. normanpitkin
    normanpitkin
    from london
    Sorry , photo wouldn’t load. But the other car was a different one but still with an odd vin number , seems like the numbers weren’t always as the vin checking site thinks
  30. warhorseracing
    warhorseracing
    from cameron wv
    One pop rivet, one Phillips head screw attaching it. RUN!
