Ford wide five vs VW wide five wheels?
Discussion in 'The Hokey Ass Message Board' started by Levis Classic, Jul 24, 2006.
  1. Levis Classic
    Levis Classic
    Are the Ford and VW/Porshe wide five wheels the same bolt pattern?
    Sure looks the same.
    Thanks
  2. Outback
    Outback
    from NE Vic, Oz
    Nope, had both in the shed at once, they don't look so close when side by side, the Aussie FJ holden pattern is different too.
    Outback
  3. Nope... the Ford pattern is much larger.
    VW - 5 x 205mm (approx 5 x 8")
    Wide Ford - 5 x 10.25"
  4. BigMikeC
    BigMikeC
    I've lead a sheltered life. WTF are "wide 5's"? Thanks -Mike
  5. TomH
    TomH
    Ford bolt patteren from '37 to '39. Blots were at the outer edge of the brake drum.
  6. 26 FlatRod
    26 FlatRod
    I had a set of them on the original 36 Ford that I started with. I wouldn't be surprised if they were on 35s as well.
  7. Elmo Rodge
    Elmo Rodge
    They were not on '35s. For a test, you can put your head through a Wide-Five. If you try that with a VW you will hurt yourself. Wayno
  8. TomH
    TomH
    Sorry, had my head my up ***....... '36 to '39, but NOT '35.
  9. Bugman
    Bugman
    However, Stock Car wide 5's are the same old Ford pattern :)
  10. KIRK!
    KIRK!
    Wide fives...
  11. spicoli
    spicoli
    from in a house
    big mike -------- wide fives for vw's were on all pre '66
  12. Bugman
    Bugman
    Make that pre-68 :)
  13. BigMikeC
    BigMikeC
    Thanks Kirk. The descriptions weren't getting thru my skull. Pictures work every time! -Mike
  14. Im not 100% sure, but i think the english fords, anglias and prefects were the same pattern as VW!
  15. UKAde
    UKAde
    from Oxford UK
    very close but not quiet ,, I have both tried to put some nice wide vw wheels on my ford 100e based modified ,,,the wheels would go on but the nuts wouldnt centre in taper,,,,
    i'm sure people have run this combo before as it is that close,, but not close enough for me to sleep at night
