Ford Y Block - need help
Discussion in 'The Hokey Ass Message Board' started by Chuck-o-saurus, Jun 19, 2009.
  1. Chuck-o-saurus
    Chuck-o-saurus
    I've got a 57 Ranchero with a froze 272. I want to drop something in it just to motor around the yard while working on the body. I found a 292 pretty cheap close by. Will it bolt it? Old Ford engines are not my thing. Any other ideas. Central coast of CA. Thanks.
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep ,all the Y blocks should interchange no prob. as far as the basic engine goes. Some of the old engine accs. may need to be swapped.
  3. luvzccr
    luvzccr
    i did a swap from a 223 to a 292 last year in my 58 fairlane. i got a lot of left over parts from the 292. if you need any you can always pm me, i was planning on going to the beach again sometime soon, im in bakersfield, i went to arroyo grande not that long ago, nice town :)
  4. texasmark1
    texasmark1
    from Houston,TX
    y-blocksforever forum
    for all your Y-Block needs!
    check it out!
    Mark
  5. yep it should drop right in.. If it came out of a truck or a t-bird it will have a mounting plate on the front at the bottom of the timing cover but you won't need that i don't think
