Technical Ford?
Discussion in 'The Hokey Ass Message Board' started by 51504bat, Feb 1, 2024.
  1. 51504bat
    51504bat
    A friend sent me this photo and asked if I knew what make and year it is. I'm guessing Ford big truck. At first I thought 30/31 but the headlights look older, maybe early V8, 32-34? I also asked on the FTE and Ford Barn but I thought I'd tap into the HAMB data base. Any thoughts? Thanks. truck.jpg
    Deuces, SS327 and chryslerfan55 like this.
  2. alchemy
    alchemy
  3. 51504bat
    51504bat
    Thanks. Less than 15 minutes:cool:
  4. fastcar1953
    fastcar1953
    Dang , I thought it was a Dodge. :p:p
  5. Budget36
    Budget36
  6. You thought correct :p:D:p:D
  7. RodStRace
    RodStRace
    Deuces and 51504bat like this.
  8. manyolcars
    manyolcars
    is that a 32 firewall?
  9. chickenridgerods
    chickenridgerods
    from DSM, IA
    No. It's a '33/34 style firewall.
    The radiator also leans back as done on the '33/34.
    Deuces and lothiandon1940 like this.
  10. JohnLewis
    JohnLewis
    I'm no expert and probably wrong, hard to see in the picture... based off the Leafs I would guess a Oregon Ashwood tree. As far as the truck goes, I don't know. I would believe alchemy, but you cant discredit vandenplas as everything is a dodge...
  11. Toms Dogs
    Toms Dogs
    from NJ
  12. alchemy
    alchemy
    Only ways I know to further narrow it down between 33 or 34 is the grille, hood, and back rib of the cab. None of which can be seen from this photo.
    lurker mick likes this.
  13. 51504bat
    51504bat
    Photo was taken of the truck along the Russian River in Northern California.
  14. JohnLewis
    JohnLewis
    Makes sense, they span Northern California through Western Oregon into Southern Washington. Neat Picture though, would make a nice background.
  15. Corn Fed
    Corn Fed
    I edited my initial reply.
    Based on the triangle shaped window on the front wheel , I am going to say this is a '33. The '34 and later big trucks had a slightly rounded opening. When Ford went to the full floater rear end in '34, they had to make the bolt pattern pattern bigger which changed the window.
  16. 51504bat
    51504bat
    Thanks for all the info. I p***ed it on to my friend.
