Technical forged from what ??
Discussion in 'Traditional Hot Rods' started by land, Nov 17, 2018.
  1. sloppy jalopies
    sloppy jalopies
    henry first used vanadium on T axles... think he got it from a trip to france…
    strong but not brittle.
  2. pitman
    pitman
    "Just a tincture dear, nothing more!" :rolleyes:
    Ned Ludd likes this.
  3. 19Fordy
    19Fordy
    3% is incorrect.
    Steel is an alloy of iron and carbon in which the carbon content ranges up to 2 percent (with a higher carbon content, the material is defined as cast iron). You can see this in the Iron Carbon Equilibrium Diagram.
    https://www.google.com/imgres?imgurl=http://practicalmaintenance.net/wp-content/uploads/The-iron-iron-carbide-equilibrium-diagram-labeled-with-common-names-1.jpg&imgrefurl=http://practicalmaintenance.net/?p=1315&h=683&w=631&tbnid=oMwrQ4XiArYN2M:&q=iron+carbon+equilibrium+diagram&tbnh=160&tbnw=147&usg=AI4_-kSOGEQksJj6D40a2dKPx2qphQqsZw&vet=12ahUKEwjzkpu3sOPeAhWEmuAKHRrJAAQQ9QEwAHoECAcQBg..i&docid=fdRQ0y8kI1MgcM&sa=X&ved=2ahUKEwjzkpu3sOPeAhWEmuAKHRrJAAQQ9QEwAHoECAcQBg
  4. Atwater Mike
    Atwater Mike
    So there...
    Truck64 likes this.
  5. Blue One
    Blue One
    from Alberta
    3% is way off base. Wrong information is worse than no information. Educate yourself before posting
    https://www.engineeringtoolbox.com/aisi-sae-steel-numbering-system-d_1449.html
    Example AISI/SAE No. 1020
    • the first digit indicates that this is plain carbon steel.
    • the second digit indicates there are no alloying elements
    • the last two digits indicates that the steel contains approximately 0.20 percent carbon
    The last 2 digits indicate carbon content in hundredths of one percent.
    So, 1018 is a plain carbon mild steel containing 0.18 % carbon.
    Truck64, land and pitman like this.
  6. gimpyshotrods
    gimpyshotrods
    Me.
    Ned Ludd, pitman and Hnstray like this.
  7. Truck64
    Truck64
    from Ioway
    Bottom line guys, at the end of the day, if we leverage our synergies and drill down on our core competencies the stakeholders are going to be proactive, not reactive. This is a win-win.
  8. GuyW
    GuyW
    Dude - did you type this message before or after your coffee? What's in that coffee??
    Truck64 likes this.
  9. Truck64
    Truck64
    from Ioway
    διδακτικός (two scoops)
  10. pitman
    pitman
    Mestillstuck on da Met-Al-Lurgy. :eek:
    Deeduck that!
    Truck64 likes this.
  11. gimpyshotrods
    gimpyshotrods
    It's all Greek to me.
    Truck64 likes this.
  12. All metal, (meaning every last bit of every metal) is cast. It's melted and poured out of a crucible or ladle. Minerals are added or removed and the shape is changed over and over and over till they get what they want,,, an I beam a round bar, a flat plate that gets slit and bent and welded into a pipe or box tube or a brake rotor.
    Ever wonder why 20 ga material is thinner that 11 ga,, the bigger the number the thinner seams backwards.
    Well the number represent the the number of times it went thru the thinning rollers.
    Yes all the sheet metal was cast.
    metlmunchr, GuyW and Hnstray like this.
  13. gearheadbill
    gearheadbill
    Just a couple more examples
    steering arms. 1 set Ford forged....1 set current aftermarket 'forged'. 20181121_194403_resized.jpg notforged.jpg
    31Vicky with a hemi and GuyW like this.
  14. DDDenny
    Vanadium, Valerium, Valium, whatever gets you through the night.
    Vanna White is what works for me!
    You young guys probably don't even know who that is.
    31Vicky with a hemi likes this.
