Technical Forged Piston Choice
Discussion in 'Traditional Hot Rods' started by 37_Ford, Jan 13, 2024.
  1. 37_Ford
    37_Ford
    from Illinois
    284 ci Flathead with 5-6 lbs boost. Street and strip use.
    Ross Forged: 2618 Alloy (part: 80578). Metric rings (1.5, 1.5, 3.0) Top ring moly coated
    Icon Forged: 4032 Alloy (part: IC626). Rings (1/16, 1/16, 3/16) Top ring moly coated
    * Rings listed are supplied with pistons
    Installation Recommendations.
    Ring clearance .005 per inch. Same for both pistons
    2618 alloy .001-.0015 additional bore clearance.
    Differences:
    Ross piston: stronger alloy, recommended for boosted applications, bigger bore clearance, piston slap when cold, additional friction and wear.
    Icon piston: softer material, more prone to detonation issues, smaller bore clearance, less piston slap and wear. Uses very wide oil ring compared to other Flathead forged pistons
    ****** rotating ***emblies now come with the Icon forged piston and rings listed above. No customizations are available.
    Thoughts
  2. Ebbsspeed
    Ebbsspeed
    I've never used Icon, but have had no issues with Ross.
    How much is a little noise at startup going to bother you, and are a tiny percentage more friction and wear really going to matter, unless you're driving tens of thousands of miles each year?
    How much difference in price?
    ekimneirbo and jimmy six like this.
  3. joel
    joel
    I don't think there is much difference between the piston selection; I have known guys that ran stock pistons and head gaskets in sbc with roots blowers at those boost levels. I would worry about the bottom end more. I ***ume you are using a **** rotating ***embly. BTW I recommend forged pistons on any of my engines. I think I would use Cometic MLS head gaskets.
    Mikus Maximus likes this.
  4. Good recommendation on using Cometic gaskets for a blown application. It is very important that your deck/head surface finish is correct for these head-gaskets - talk to Cometic before you have your machine work done.
    Mikus Maximus, 73RR and ekimneirbo like this.
  5. gimpyshotrods
    gimpyshotrods
    Ross makes all of the pistons that I use.
    Zero issues.
    Desoto291Hemi and ekimneirbo like this.
  6. Bandit Billy
    Bandit Billy
    I bored my 471 blown, 8BA .125 over and used Ross pistons on a Merc crank. No regrets.
    Desoto291Hemi likes this.
  7. ekimneirbo
    ekimneirbo
    Basically either one of them should work fine in a street application with only 5-6 lbs of boost. For that reason, I think I would go with the one that doesn't have piston slap when cold. Its always going to be annoying to hear a noise coming from a sizeable investment, and piston slapping is never a "good" thing even if its tolerable.
    If you get detonation with either piston type, its likely to cause damage although the stronger one may take a little longer. As long as your engine is tuned properly and you don't have detonation......either should be fine. Thats the logic I would use with any engine, not just with a flathead. If it was a racing engine, then I would go with the stronger piston because of the extremes that those engines endure.
    Note: I'm not implying anything wrong with using the Ross piston, but you will find people tend to ask you what that knocking sound is. Friend of a friend had a beautiful truck with show quality everywhere. Engine had piston slap upon startup. He couldn't stand it, and had the engine rebuilt. Its more about what works for your type of needs.
    Beanscoot likes this.
  8. I've found that most of the flatheads I build have loud exhaust systems (many with no mufflers) - so I can't hear any potential piston slap anyway! LOL
  9. seb fontana
    seb fontana
    from ct
    I can't say that I have ever heard what piston slap sounds like, been under a rock maybe?
  10. 427 sleeper
    427 sleeper
    I've always been a firm believer of letting the engine get up to temperature before driving, so it shouldn't really matter one way or another, about the piston slap... JMO.
    loudbang, Desoto291Hemi and SS327 like this.
  11. gimpyshotrods
    gimpyshotrods
    They can put an anti-friction coating on the skirts, too, if that helps.
  12. ekimneirbo
    ekimneirbo
    It sounds similar to a loose rocker arm tapping..........but after you probe around and try adjusting the the rocker arms, its still there. Sometimes you can tell with a stethoscope that its lower in the engine, but you still adjust the rockers and hope thats what it is.............
  13. Ebbsspeed
    Ebbsspeed
    Yep, but instead of a "ticking" sound that loose valvetrain makes, it's more of a heavy "clacking" sound like every piston pin is loose, but it only lasts for 30 seconds or so and then the pistons expand enough to tighten up the clearance, the ***umption being that the pistons are fitted correctly.
  14. chicken
    chicken
    from Kansas
    Start up an early 5.3 (LS) Chev in cold weather and you'll know what piston slap sounds like! (Apologies for the OT reference but it's so common it's the easiest.)
    427 sleeper likes this.
  15. SS327
    SS327
    I’ve never heard of Icon pistons.
  16. ekimneirbo
    ekimneirbo
    I agree with your explanation, but its not necessarily all pistons in an engine that you can hear. The one I mentioned above only sounded like one piston, and it did not go away quickly.......it continued for as long as I was trying to trace the noise .....which was about a half hour on a lift. I turned the repair job down because I was afraid I'd scratch the paint. I'm just pointing this out so that the OP will know that generally the noise subsides like you said, but there is also a chance that it won't.........and if the car is driven a lot the clearance will increase. If its a race car and gets no real mileage, it should be fine.:)
    Ebbsspeed likes this.
  17. Ebbsspeed
    Ebbsspeed
    That sounds like one wasn't fitted correctly if it continued to make noise for that long. Hence my previous comment "the ***umption being that the pistons are fitted correctly." I use a machinist who is very **** about fitment and engine clearances. He creeps up on each cylinder size a half thousandth at a time with the hone when he gets close to the clearance he wants, measures to the ten-thousandths, and charges accordingly. Well fitted forged pistons (to me) are a joy to listen to at startup. On a cold startup I don't move the car until the symphony is over.
  18. banjorear
    banjorear
    What is the price difference between the two? If it was me, the fact that the Ross uses metric rings is what I would use.
  19. Budget36
    Budget36
    My LS5 is claimed/spec’’ed with forged pistons, I’ve never heard “piston slap” when starting it.
    Maybe a factory engine is different from aftermarket parts?
  20. Call 'Ed' in sales at Ross - good guy and will work with you to help you get exactly what you need.
    Make sure you put the crank and a rod/pin in both banks and measure the exact compression height (current height - will usually vary side to side). In the end, you need to achieve a squish of .040 to .045. Contact Ross about dome height - usually it is .187. Do your math calculations so you know the deck height on each side.
    Usually, I square deck the block to ensure that both sides are exactly the same height - this is then used to determine the piston pin location (compression height). Standard stocking pistons for a given stroke will rarely get you exactly the compression height you'll want - which is why the above is necessary. I usually tune my compression height to within .002 of the final number of .040.
