Found a Zephyr V-12
Discussion in 'The Hokey Ass Message Board' started by LoneWolfNoCLub, Jun 12, 2011.
  1. I know where a Zephyr V-12 is, guy says it's a 1943, but as far as I know all we were building in 43 was planes, tanks, bombs, etc..... I could be wrong however. Wants $975 for it. I have absolutely no use for it, but was thinking of buying it anyways. There is a guy here in Mi with a bad*** phaeton with a V-12 in it, was in the ba*****t at Autorama this year.. Hmm.....
    James
  2. fbama73
    fbama73
    I have no use for one either. Put one in front of me for a grand, and I'd find a use REAL fast.
  3. Deuces
    Deuces
    Drop it in a 5 window coupe... That be wicked!!! :D
  4. propwash
    propwash
    from Las Vegas
    Determining that it's a Lincoln should be your first priority. If it is indeed a Zephyr, your second prioity should be getting it out of his hands and into yours (legally, of course). THEN...you can figure out "what to do with it" as I'm quite sure you'll have tons of offers if you decide to sell it, or as many suggestions on how to build it.
    dj
  5. Nick Flores
    Nick Flores
    I'm with propwash on this one. Identify and procure.
  6. rschilp
    rschilp
    Last time I bought one I sold the engine alone for way more than that before I got the car home.. good buy for $975 if the engine is in any way useable.
  7. propwash
    propwash
    from Las Vegas
    so...is there going to be a happy ending to this story? Tell me you bought it....post up a picture. Inquiring minds want to know...
    dj
  8. 32Essex
    32Essex
    from Texas
    The best reason in the world for a new hot rod, "but honey , I've already got all the parts, now all I need is . . . . . . .
  9. OoltewahSpeedShop
    OoltewahSpeedShop
    With Sellers making finned heads and 3x2 intakes, makes the old V-12 alot more appealing.
    Now if we can get him to make us some Speed Parts for the 337....
  10. resqd37Zep
    resqd37Zep
    from Nor Cal
    Wow, I didn't even know Sellers made Zephyr parts. For the longest time the only one making fiined V12 heads was the Kearny Foundry out of San Jose Ca. They also do the 3 x 2 intake. Ken Austin makes a beautiful 2 x 2 and 3 x 2 for the V12. Good luck with your motor.
  11. Frenchy Dehoux
    Frenchy Dehoux
    As far as I know they never had 1943 Zephyrs. In 1942 were the last year which had the bigger bore other than 1946 to 1948 Lincoln.
    Frenchy
  12. brad2v
    brad2v
    My thoughts exactly, I wouldn't even care what variety of V12, it's a V12 fer Chrissakes.
  13. SleightsburghMC
    SleightsburghMC
    Definitely make sure its usable because they are one pricey motor to rebuild, especially if it is an early poured babit motor. The later ones were insert bearings and this should be if its a 40's v12. Parts like hydraulic lifters are expensive as well. The speed parts are on a different planet from V8s. They do look cool but are expensive.
  14. stillrunners
    stillrunners
    from dallas
    can you say "Columbia"......hope I spelled it right.....or wright.....
  15. KrisKustomPaint
    KrisKustomPaint
    Haven't you heard the song? Just put a Model a body on it. "That story is true I'm here to say, I was driving that Model A."
  16. FANTM58
    FANTM58
    There was 1 for sale at the swap meet at the Good Guys Show a few weeks ago here in Colorado.Its was a 4 door sedan,a real claen runner !!
    He was asking 11 - 16 thousand ?
    Sorry no pictures, 1941 ?
  17. MeanGene427
    MeanGene427
    from Napa
    If anybody wants one around NorCal, I have a bunch of '46 stuff- one complete engine/OD trans (with the hard to find OD solenoid) and everything for a second one except the block & pistons- so there's two intakes, carbs, exhaust manifold complete with a head pipe, heads, water pumps, oil pans, flywheels, clutches, complete front & rear axles with brakes 'n springs, friction shocks and extra rear end & tube stuff, 5 original script wheels, guides 'n valves, extra magged crank and set of rods, trans parts, lotsa stuff- all for $2500. I was going to put it in my '55 F100 for shock value, but sold the truck. Too much **** and too many projects, come and get it
  18. Bleach
    Bleach
    The bigger bore engines were also unfortunately more prone to overheating because of the thinner cylinder walls. Lots of owners of those Lincolns at the time opted for junking the engines and swapped in later model V8 flatties or the just becoming available OHV engines.
