Projects Found on Kijiji 1928 Roadster!
Discussion in 'The Hokey Ass Message Board' started by RetroSteel, Apr 7, 2012.
  1. brady1929
    brady1929
  2. Thanks!
  3. Blue One
    Blue One
    from Alberta
    It looks really nice. I would appreciate you sharing the details on mounting the cycle fenders you need to p*** inspection.
    As well as pictures of the fenders themselves mounted on the car.
    I'm sure some others may be interested too if they are well done and give the option of running with them in place or removing them to run fenderless.
  4. I'll post some pics on the fenders/build for sure! :D
  5. Blue One
    Blue One
    from Alberta
    Thanks, sometimes those details are left out. I have looked at sources you suggested for cycle fenders, but so far have not found much.
    A concern on using motorcycle fenders would seem to me to be whether or not they would work with the diameter of say a 29.5 " tall rear tire.
    My rear tires are 255-70/15.
    And the smaller front diameter tires will need a different fender diameter as well.
  6. TigerFan
    TigerFan
    from Athens, GA
    Just when I thought I'd seen all of the best roadster build threads, I find this. Great work!
    What did you tie the interior tubing into, the sub rails? I couldn't quite tell from the picture.
  7. I have this habit of saying that i won't detail it, or make it shiny..but it always turns out the same way? I guess that's the way i like them!:cool:
    There are a lot of talented builders here on the H.A.M.B. and alot are much more talented than me , but i try my best, and if you like it, hey that's great too! :D
  8. While i borrowed ny son' rollers for the paint shop. He used my wheels & tires,
    He will have 16 inch steel rims with Black Wall Coker Bias Ply tires. His tires will be slightly higher & wider on the rear.
  9. daddio211
    daddio211
    This car doesn't **** either! You two build some really cool ****!
    Sent using the NEW Droid HAMB app from atop my toilet.
  10. Thanks Eric!
    That is some cool **** sent, using the NEW Droid HAMB app from atop my toilet! :cool:
  11. daddio211
    daddio211
    LMAO
  12. Mounted a set of fog lights today
    Also a custom center console (with two 12volt ports & drink holder) was installed & mounted a 2 speed fan on the p***enger side. On the left side below the dash you can see the ignition switch & headlight & foglight pull switches.
  13. yblock292
    yblock292
    beautiful exhaust manifolds!
  14. ss34coupe
    ss34coupe
    Right on! You guys are doing us Vancouver Island rodders proud!
  15. AHotRod
    AHotRod
    The car looks great!
  16. Barn Hunter
    Barn Hunter
    Love both cars...there's talent in that family. Good luck on your journey.:)
  17. Speedway Polished Stainless Steel Ram Horns, They are a work of art!
    Thanks ss34coupe! Vancouver Island has always been a meca of talented builders who create beautiful hotrods!
  18. Thanks AHorRod!
    Thanks Barn Hunter! It's neat when you can p*** on your p***ion to your kids!:D Got a little behind in my build posts, so i'll be posting more frequently! Can't wait for the BIG TRIP!:)
  19. Hackman
    Hackman
    from Butte, MT
    Looks awesome man. Good on you. The detail is noticed.
    Enjoy
    Hack
  20. Thanks Hackman!:D I really like your chopped T coupe!
    Here's a couple more of the roadster. Leaving the doors off while I do the wiring.
  21. Finished the wiring! Bent up a little panel for the ignition switch and light switches. It also has the turn indicator lights.
    The roadster doors were left off while until the wiring was finished. (good tip> Since the roadster body was up on jackstands and when wiring you are constantly in & out of the car you don't want to open & close the doors, as they will not align up correctly with the body. Best to leave them off):cool:
    Here's a pic with the doors on the roadster now
  22. Shown here with my sons 31 Hemi Roadster build
  23. ss34coupe
    ss34coupe
    You are both maintaining the fine tradition of hotrodding here on Vancouver Island!
  24. gordspeed
    gordspeed
    from Oregon
    Those two look sweet sittin' there! Cheers to both of you on your builds! :)
  25. Thanks ss34coupe, much appreciated!:D
    Thanks gordspeed! Keep us posted on your 34 pickup build!
  26. 40FordDeluxe
    40FordDeluxe
    Very nice, I love them both!! Keep up the great work!
  27. A friend has been helping me with the exhaust. Using 2 inch aluminized straight pipe & some 2 inch 180 degree U Bends. Went with 2 inch as i want the tailpipes to go over the rear axle housing and need the clearance. Using Flowmaster Hushpower HP 2 Shorty stainless mufflers & welded flanges so i can unbolt the tail pipes. Will use 2 inch polished stainless pipe that i had left over from my '27 T for the tailpipe tips. Right now it is tacked, but once it is fully welded & ground I will get the pipe from the exhaust manifold to the muffler ceramic coated in silver.
  28. Thanks 40FordDeluxe! It's kinda cool building two roadsters at the same time!:D
  29. Here are some pictures i took today, very close to firing up!:)
    Ceramic coated the exhaust in a silver
    Tailpipes go over the rear end and exit 1/2 inch past body
    The hood is now on the roadster
    3/4 front view
  30. hooliganshotrods
    hooliganshotrods
    Very nice, both of them:cool:
