Found this old Rocket...
Discussion in 'The Hokey Ass Message Board' started by el Scotto, Apr 11, 2008.
  1. el Scotto
    el Scotto
    from Tracy, CA
    $50 and she followed me home.... It think it's 324. It's got aluminum pop-up pistons and a roller cam.
    Don't know much else about it, it's my first Olds.
    I'd like to build it, I think.
  2. DON_WOW
    DON_WOW
    What you have is a 1955 324 .
  3. el Scotto
    el Scotto
    from Tracy, CA
    Flipped it over popped off the pan, the rods are Howard aluminum rods!!
    We took a mic to it, and it looks like the bore is at 3.938 and the stroke (if measured correctly is 3.92!
    I'm way more than stoked!
  4. CGkidd
    CGkidd
    You ****... Honestly good score. Any other goodies with it?
  5. chop32
    chop32
    If your measurements are correct and my math is right (bore x bore x stroke x.7854 x # cylinders) it works out to be 382 cu. in. motor (381.96). Cool find!
  6. Bondoboy
    Bondoboy
    lucky *******
  7. kurts49plym
    kurts49plym
    from IL
    That's incredible!
  8. Standard bore; 3.8750 (must be .060 over)
    Standard stroke; 3.437
    394 was 4.125 bore x 3.688 stroke
    May be an after-market crank?
    Awesome find! Get any heads?
  9. publicenemy1925
    publicenemy1925
    from OKC, OK
    50.00 bucks you can't go wrong. I am always leary of any motor that is tore down , and the owner has no knowledge of how it got that way. It has some really cool parts. Give it a good once over. Really cool motor.
  10. BOHICA
    BOHICA
    Try (bore x pi) x stroke x # of cylinders.
  11. Durod
    Durod
    from DFW, Tx
    what the hell? that's a crazy find! im super jealous.....what a great motor.
  12. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Yeah man, insane score. Nicely done.
  13. Halfdozen
    Halfdozen
    High compression pistons, Howard rods, roller lifters, probably means a wicked cam.
    Best fifty bucks you'll ever spend.
    Did you just get the short block or were there other parts with it?
  14. el Scotto
    el Scotto
    from Tracy, CA
    Just the short block as you see it, and the crank and waterpump pulley. The guy I got it from said the previous owner of his house restored old Corvettes, so maybe that's why it was left behind?
    I'm going to start collecting parts to put it together, need to find good heads I can port, I've read that the '56 heads are the best for this family of engines, the ****** related stuff, and the valve train, I think these year engines used 1.8 rocker arms?
    I think I just became an Olds guy, too.
  15. captainjunk#2
    captainjunk#2
    a most awesome score
  16. yorgatron
    yorgatron
  17. 52 csb
    52 csb
    Hey el Scotto you got a great start there!!!! I think you have a forged crank also !!!! good luck 52 csb:D
  18. Fraz
    Fraz
    from Dixon, MO
    Holy **** man, 50 bucks got you that? I hate you now. Seriously. 50 bucks around here gets you bout half a tank of gas.
  19. HHRdave
    HHRdave
    from So Cal
    Cool find and you get some MATH lessons with the post for free!!!!
  20. CGkidd
    CGkidd
    All the early olds cranks were forged.
  21. 55olds88
    55olds88
    $50 good score....... that would never happen here in N.Z. :)
  22. chop32
    chop32
    Actually, that would give you the cir***ference of the bore x stroke x # of cylinders which isnt correct.
    To get the area of the cylinder you would need: Pi x cylinder radius squared x stroke,
    Then multiply by the # of cylinders...Which equals 380.98 Cubic Inches!
  23. BOHICA
    BOHICA
    Doh! You're right. I apologize. Thanks for setting me straight. :eek:
  24. ratt7
    ratt7
  25. Nads
    Nads
    from Hypocrisy
    You scored, I'm happy for you.
  26. nochop
    nochop
    from norcal
    Scott you still got this block?
