Technical found this on CL
Discussion in 'Traditional Hot Rods' started by gdrummer, Nov 27, 2022.
  1. Toms Dogs
    Toms Dogs
    from NJ
    Truck engine, as per Millersgarage (above).:D:rolleyes:
  2. Hitchhiker
    Hitchhiker
    That would be a 239ci 100hp engine. Not 85 like stated above.
    41 GMC K-18 likes this.
  3. flatheadpete
    flatheadpete
    from Burton, MI
    Where are you located? A local HAMBer would prolly be more than willing to come lend a hand.
  4. F-ONE
    F-ONE
    from Alabama
    It still could be an 8BA but set up like an 8RT. It has 8BA heads which were slightly higher in compression than the 8RT heads.
    The water pumps and oil pan are definitely 8RT truck parts.
    Likely it is a 1951-maybe '52 engine due to the B1** casting on the block.
    If it is an 8RT it should have RT or 8RT close to those castings mentioned above.
    This engine will require an 8RT "Truck bellhousing adapter" (mini-bell) and the truck starter plate. You have to have these pieces to bolt the starter on.
    8BA "Car" bell is completely different with a different oil pan, bellhousing and starter plater.
    THESE PARTS DO NOT INTERCHANGE!!!!!!!!!
    but everything else does pretty much.
    Hamtown Al likes this.
