Customs Four Barrel or Two Barrel Carb
Discussion in 'The Hokey Ass Message Board' started by John316, Apr 28, 2013.
  1. John316
    John316
    from Alabama
    I have a 1956 Chevy 265 engine that I am about to replace the intake and carb on. I believe the engine originally had a two barrel carb on it. It is currently running a four barrel that is too big; an 800 cfm.
    Can I run a Quadrajet four barrel on this, say a 640 cfm, or should I go with a two barrel?
    I don't have a two barrel carb and intake so I am not wanting to spend any more money than I have to. I am real sure this engine came out of a 1956 Chevy car. I have pictures of the engine being put in the car dated Oct. 1956.
    I have a friend how says they had a 283 in 1956 and this engine is not a 265. Not really believe this.
    Also, the four barrel and intake that I have is from a mid to late 60's 350 engine. Will this intake fit on a 265? I don't know how many small block parts will interchange. The newer intake has a place for a choke thermostat that I believe will help with starting and running.
    Some advice and help with this project would be greatly appreciated.
    Thanks.
  2. Rich Rogers
    Rich Rogers
    Depending on what intake is on it, you could use a 500 cfm 4bbl. carb alot better than even the smaller Q-jet. The 265 was 2bbl and the 283 was 1st built in 57 afaik. I'd go with either a 450 Holley , or the 500 Edelbrock
  3. Dan Timberlake
    Dan Timberlake
    Here is an image from the 1955 SAE paper "The new Chevrolet V8 engine".
    It had charts for 2bbl and 4 bbl dual exhaust versions of the 265.
    I rescaled them so the HP and torquage have the same vertical scaling.
    The text of the paper does not mention a cam change when the 4 bbl etc is added.
  4. hoop98
    hoop98
    from Texas
    If the intake you have is for a Q-Jet run it. The Q-Jet has very small primaries and the secondaries are demand operated so it works well in low demand applications.
    If, you have a Square bore manifold then the small four barrels mentioned above will work fine.
    Hoop
  5. hoop98
    hoop98
    from Texas
    In 56 there were 4 265's a TurboFire 163, TurboFire 170 (Powerglide) Turbofire 205 (4bbl/dual exhaust) and TurboFire 225 (2 4.bbl).
    The 170 and 205 had the same cam, about 18 degrees more duration and .040 more lift . The 225 had another ~.040 lift and was a solid lifter, there was an optional cam too.
    Hoop
