Technical Four Speed Muncie Tech Info
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Jan 15, 2021.
  1. ekimneirbo
    ekimneirbo
    Stumbled across some info that I thought would be helpful for those who enjoy having a 4 speed in their vehicle. Feel free to add any other info that might help others with these transmissions.
  2. ekimneirbo
    ekimneirbo
  3. saltflats
    saltflats
    from Missouri
    Can't say I ever rebuilt an manual transmission that could be fixed with just bearings and synchro rings, they all needed gears, synchro hubs and sliders also. Maybe I was just to picky.
    GlassThamesDoug and Deuces like this.
  4. bchctybob
    bchctybob
    Thanks for posting this. I’ve got two on the shelf and one is pretty noisy. I’ll probably have to go through it if I decide to use it. More good info for the reference library.
  5. Deuces
    Deuces
    M-22s have a drain plug and are usually noisy.... :cool: I let one go for 4 bills some years back... :confused::(
    31hotrodguy and chevy57dude like this.
  6. pitman
    pitman
    The straighter the gears...
    (Say what sonny?)
    Deuces likes this.
  7. Black Panther
    Black Panther
    from SoCal
    A second drain plug can be added to earlier Muncies and was standard for 1970 and later transmissions so that isn't a sure way of checking for M22s. Since the most common ones are 1969 and later, just check the ***embly code that looks something like this: P9A22 C. Look for the C at the end...it means M22. Also the letter after the P is the year..9 for 69..0 is 70..and so on.... there were M22s made before 1969..but they are super rare...the vast majority of M22s are going to be 1969 and later.. Either early or late..no rings on the input and look at the straighter cut gears. Count the teeth on the input shaft...all M22s are close ratio too.
    They are noisy....like a kinda quiet gear drive instead of a timing chain.
  8. DDDenny
    The M-20 (wide ratio) for my 67 Nova is a "parts barrel" built trans, I had the guy that sponsored the turbo 400 in my race car build it in 1983.
    It is basically a 69/up main case and internals with the earlier sìde cover ***embly so the early style factory shifter could be used, also has the speedo outlet on the p***enger side which is done so the shifter can mount farther forward for the earlier Novas.
    66-67 Nova shifter.
    This is also a good Muncie ID source.
    http://chevellestuff.net/qd/muncie.htm
  9. DDDenny
    Roger that!
    In 1970 I was 16 and had just got my drivers license and was given the (most memorable) opportunity to drive a new LS6 Chevelle with an M-22.
    What a beautiful noise!
  10. Deuces
    Deuces
    Almost sounds like a very loud dentist drill at high rpms....:D:D
    The one I sold came out of a very rusty 1969 SS F-body.... I ended up sending that one to the s****yard after I stripped it of all the goodies...:(
  11. Bad Bob
    Bad Bob
    from O.C. Baby
    My Coupe has a M22, AND a Quick-change! It's LOUD!!!
  12. DDDenny
    The only thing missing then is the Pete Jackson gear drive I have, it's the "noisy" one.
    Brand new, installed, never fired, you can have it.
    One of those "what was I think'n".
    Now, back to Muncie 4 speeds.
    catdad49, Deuces and arkiehotrods like this.
  13. pitman
    pitman
    w/a 327" and 3:08 rear, a rebuilt M20 was a wide ratio godsend. Ran it 100k mi. in my '31 coupe. The spread between gears was close to ideal.
  14. bill gruendeman
    bill gruendeman
    I just did a m 20 for my o/t gto (80000 mile car), the reverse gear, bearings and syncho rings is all I had to replace. But it was a good working trans when I parked the car, 44 years ago.
    Algoma56, pitman, rod1 and 2 others like this.
  15. Bad Bob
    Bad Bob
    from O.C. Baby
    That's why I got rid of my elec fan! haha Hated the sound!!!
  16. chevy3755
    chevy3755
    very good.....
  17. Tim
    Tim
    from KCMO
  18. GlassThamesDoug
    GlassThamesDoug
    Like the nova shifter..
  19. Bad Bob
    Bad Bob
    from O.C. Baby
    Well, my M22, Rock Crusher just broke on me Sunday. Now, i'm looking for a M21 or M20 to replace it. This all depends on how much it costs to repair it.
    31hotrodguy likes this.
  20. MeanGene427
    MeanGene427
    from Napa
    That's why Munchie prices are high these days, many of them went boom long ago
    GlassThamesDoug likes this.
  21. GlassThamesDoug
    GlassThamesDoug
    Broke a 68 muncie banging 2nd showing off, went bang...sounded like driveshaft was coming thru floor.
  22. iwanaflattie
    iwanaflattie
    I just got one,thinking of putting it behind a 270 gmc 6 inline
    LAROKE, Deuces and GlassThamesDoug like this.
  23. Kan Kustom
    Kan Kustom
    Thanks for posting the info. I have three Muncies. Will probably have more sooner than later.
  24. Gus68
    Gus68
    from Minnesota
    Beware of the NO GROOVES on the input. I ran into one with out grooves on the input and a large 1 inch cluster pin. Turned out to be an M20 that had the input replaced once in its life. They used the grooves to identify them at the factory but replacement ones have no need for them.
  25. lumpy 63
    lumpy 63
    But at least they shift
    WAY better than a toploader...:D
    2OLD2FAST and 31hotrodguy like this.
  26. DDDenny
    I guess that says something about those Shiverlay engines in front of them!:D
    lumpy 63 and Deuces like this.
  27. GlassThamesDoug
    GlassThamesDoug
    I have a rebuild kit waiting for warm weather. 70 sbc chevelle wide ratio muncie gets freshened. I have a 65 wide ratio, came ftom a 34 street rod, quietest muncie I ever had, absolutely smooth.
    31hotrodguy, Deuces and pitman like this.
  28. pitman
    pitman
    Try a Hurst Comp Plus shifter w/it. Abs. Sweet! For a narrow body car (A), extend shifter up and a couple inches of jog right.
  29. GlassThamesDoug
    GlassThamesDoug
    I had some custom shifter levers made, reg carbon steel. Machinest did a nice job.
    Deuces likes this.
  30. MeanGene427
    MeanGene427
    from Napa
    Ah, the Chebbrainwashed- all it says is the aluminum-cased Munchies were weak- which they were- and a small percentage still are lol.. Many a Munchie has been grenaded by mild small-blocks- didn't take that much
