Technical Frame boxing necessary?
Discussion in 'Traditional Hot Rods' started by Dad Was A Racer, Nov 25, 2018.
  1. Dad Was A Racer
    Dad Was A Racer
    Dave, you're right, I'm not replacing it, but to your point, Texas is a giant pain in the *** to try and register a car without a previously existing ***le. Most guys end up hiring lawyers here that specialize in this ********. You have to take the car to the DPS (equivalent of the DMV in most places) which for us is about 100 miles away, and arrange to have a senior Trooper personally inspect the car, to which you are totally at his/her mercy to determine its legitimacy, and that's where the paperwork pile just begins... So yes, in Texas, having a ***led frame is a big plus to start with.
    To the previous question, yes, the VIN is perfectly clear on the frame. It has a layer of surface rust all over of course, but the rest of the structure is solid and well worth resurrecting in my opinion. My only debate was whether or not to "modernize" it by boxing it.
    Bandit Billy likes this.
  2. gimpyshotrods
    gimpyshotrods
    You need to get past a a verifier here in California, too. It also has to look like a car.
    Luckily, there are private citizens to whom the state has delegated the authority to do this. I know one pretty well.
  3. Hombre
    Hombre
    Sadly "dirty old man" your request has fallen on deaf ears.
  4. gimpyshotrods
    gimpyshotrods
    See if you can find another frame, and use sections from it, or carefully dissect the existing damaged sections and duplicate them.
    It will be a pain in the ***, but you can do it. If you can find box tubing, rectangular or square, with the same corner bend radius, or close, you can cut it up into donor sections, and weld those together.
    What @anothercarguy showed you is exactly what you will need to do.
    anothercarguy likes this.
  5. gimpyshotrods
    gimpyshotrods
    So? Bandwidth is practically free.
  6. Ebbsspeed
    Ebbsspeed
    I've only ever done one Ford of the era that used that style frame, and had the same rust issues in the same place. I cleaned out as much as I could, and plated in inside and out. Would acquiring a rust-free frame and transplanting the VIN section of frame from the old to the new be a valid effort? Maybe that's what @gimpyshotrods was alluding to when he said "See if you can find another frame, and use sections from it".
    He likely cannot tell you exactly what he was thinking, as it may invalidate his sworn automotive hippocratic oath as a California licensed and bonded Vehicle Verifier, or result in legal issues were he to actually suggest a frame VIN swap.
  7. gimpyshotrods
    gimpyshotrods
    I would never suggest swapping identifying marks from one frame to another.
    Just remember, a properly penetrated weld, sanded perfectly smooth, always looks really keen.
  8. Ford frames are designed to twist some, boxing is not needed.
    weemark likes this.
  9. Hombre
    Hombre
    John, Are saying ALL Ford frames? Or just the frame in question?
  10. Bruce Lancaster
    Bruce Lancaster
    Do note that Ford suspension p***es forces to the frame right down the center. Chevy suspensions attached as far out to the sides as feasible and so required more stiffening. to remain straightish.
    Moriarity and dirty old man like this.
  11. cjtwigt
    cjtwigt
  12. 1946caddy
    1946caddy
    from washington
    I ***led a 35 Ford from Oregon and a 36 Ford with a New Jersey ***le and the only thing I needed was a ***le and a bill of sale, no inspection needed in Washington within the last two years. I was told I would have needed a inspection if there was no ***le and just a bill of sale.
  13. saltracer219
    saltracer219
    Yes this is true if you have a ***le. However if the ***le number does not match the frame number and if you are stopped and they want to verify the vin. you will have a big problem.
    gimpyshotrods likes this.
