Frame/Chassis Tubing Help
Discussion in 'The Hokey Ass Message Board' started by Gardener1, Mar 6, 2012.
  1. Gardener1
    Gardener1
    from Tucson, AZ
    Thought this was General Discussion. I guess not.
  2. Da Tinman
    Da Tinman
    uh Wrong forum for a rodent build.
  3. ELpolacko
    ELpolacko
    Well, I don't think this is the right forum for you, but how about some rusty I-beams, a menagerie of bed frame rails or how about "drill pipe". Should be some of that available in Tucson.
    Want a serious answer?
  4. Larry T
    Larry T
    Straight answer, lots of race cars run 2X3 framerails-----but not without a cage to brace them.
    2X4 would be a lot better and if I were custom building a frame that was out there for the world to see, I'd probably start with 2X6 so that I could cut what ever taper or curve I wanted on the front rails/horns.
    And I'd probably use something around .120 wall thinkess tubing.
    But that's just me.
    Larry T
  5. rustednutz
    rustednutz
    from tulsa, ok
    Thanx for the straight answer, Larry T. Maybe if we show the RR crowd a little "Love" and straight talk they might see the "Light" and change their evil ways.
  6. jeffbr33
    jeffbr33
    from norwich,ct
    2x4 .120 wall tubing is ok 2x3 will flex for sure,I've done it once
  7. HrdNox
    HrdNox
    from utah
    [​IMG][​IMG] Uni body/cage ok otherwise,do like said above.
