I built this out of tubing, I beam, and c-channel for setting up a frame on the top... I rough cut the vertical pieces off that I used for holding the frame in place (still has a couple inches on the bottom that will need to be removed/cleaned up). It would be good for putting steel plate on top and using as a fab table...or use it as I did... I want it out of my way this week. So, I'm only wanting $200 for it... The steel to build it was obviously far more expensive than that.
