I have a body but I need a frame. I plan on using a Nailhead for a power plant. I would like to Z the frame. Should I try and use a Model A frame or make one from square tubbing? May an after market type.. Maybe there is some plans out there I could get. Dennis
Check out Wescott's catalog or maybe their websight out of Oregon. They have always had detailed drawings and dimensions of early Ford frames in the back of their catalogs. Grab some tubing and get to work!
2 X 4 X 1/8. get (3) 10 ft pieces position over a stock frame. add 6 inches if you hang a spring behind the diff. cut, square, tack, weld. Done. Read Brianangus frame thread first!
