Frame height question on Model A
Discussion in 'The Hokey Ass Message Board' started by 201, Sep 24, 2003.
  1. 201
    201
    I could realy use a mesurment frome top of frame to ground,at center line of front axle on an A using after market crossmember,4 in drop axle and reverse eye spring(from C-E),small block,crossmember mounted to rails about 3/8 in down from top of rails. Also a mesurment from center of front hub to ground.That way I can dial in my tire dia.(24.3 in.- 185/70/14's) and life will be good! It's a ***** building something with imaginary parts ,but I can't spring for the front end stuff for a while.Tring to get rails done this week end and I can get my rear susp. pieces/parts now though.Thanks
  2. 201
    201
    Hay,I'm good for a beer if your ever around Cleveland. No free ***, though.
