frame ideas
Discussion in 'The Hokey Ass Message Board' started by slamdpup, Mar 18, 2007.
  1. slamdpup
    slamdpup
    im about to start on my 54 chevy belair frame and looking for ideas...im gonna be using mustang11 front clip...gonna be bagged in all 4 corners with triangulated 4 link....gonna fab up some tophats for the mustang11 cross memeber...also does anyone have a spec sheet or tech on installing a mustang11 clip....measurements **** like that..also custom ideas..motor mounts,shock mounts,just looking for unique ideas custom ideas ..if you guys dont mind sharing your ideas..please post pics of your frame..thanks
  2. bnkrpt311
    bnkrpt311
  3. slamdpup
    slamdpup
    damn thats nice work....anybody else got any to share?..thanks
  4. Aaron51chevy
    Aaron51chevy
    B***'s frame is about the coolest 49-54 frame I've ever seen. Ch***is Engineering and Yogi's has just about everything you need. If your fabbing the stuff up yourself just remember once you slam it nobody is gonna see it. Unlike a hot rod where a ton of the ch***is work will always be seen it's not so on a custom.
    That said if you can make a trick trunk area that would be *****en. Most I've seen are hacked up and unuseable once the car is bagged.
  5. pprather
    pprather
    The May '07 issue of Street Rodder magazine has a tech article on installing a Fatman's Mustang II in a '54 Chevy. Unfortunately it is not yet on their web site:
    www.strretrodderweb.com
    Hope this helps. I thought it was a good article.
  6. slamdpup
    slamdpup
    is it on the newstand yet?..
  7. slamdpup
    slamdpup
    gambino do you have any pics of your work on your car or 53 54 chevys that you have done work on?..or anyone else
  8. bnkrpt311
    bnkrpt311
  9. james
    james
    I noticed the negative camber logo--- check ou the minitruck sites to see some really wild framework. like sportruck.com or socalcustoms.com
  10. slamdpup
    slamdpup
    i wanted to see other 53 54 chevy frames..ive seen minitruck frames of all shapes and sizes..:cool:
  11. MIKE47
    MIKE47
    from new jersey
    I used a TCI from Walton Fabrication. Came with nice instructions. Ch***is Enginering also makes a nice MII. Both have great tech support also.
  12. evil1
    evil1
