Technical frame mount power booster
Discussion in 'The Hokey Ass Message Board' started by 1953-55 F-100 guy, Oct 15, 2025.
  1. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    on my 1954 Ford F-100 has a frame mount power booster--now the problem push on break pedal come to stop let up push again very HARD pedal not a great stop must push on it hard-- disc front--9 '' Ford drum rear-- has correct proportion inline valve---THANKS
  2. BJR
    BJR
    A booster like that only works on one side of a duel master conversion. Which side do you have it connected to? Front or back? If it stops good once, you must be running out of vacuum. You could try installing a vacuum tank to store vacuum for the 2nd push of the pedal.
  3. FrozenMerc
    FrozenMerc
    I agree with BJR, sounds like a vacuum supply problem (an yes, I realize that is an oxy-***** as we are talking about supplying nothing...)
    My daily '85 F350 has the same problem. The vacuum pump on the diesel is getting weak, and I have been too busy on other projects to replace it.
