Technical Frame Mounted Power Brake Booster - Exhaust Pipe Clearance?
Discussion in 'The Hokey Ass Message Board' started by kbuhagiar, Nov 5, 2019.
  1. kbuhagiar
    kbuhagiar
    Hello Folks,
    My 47 Plymouth has power brakes, and the master cylinder and power brake booster are mounted to the frame, under the driver side floorboard, in close proximity to the left exhaust pipe. The current booster is a 7" unit, and there is a little over 1" of clearance with the pipe. I want to upgrade to an 8" booster, but this will reduce the clearance to 1/2" or less. How much clearance is necessary
    I've always thought that so long as it isn't touching the pipe it should be OK.
    Thanks in advance.
  2. krylon32
    krylon32
    from Nebraska
    On my 40 I had about 1/2 inch of clearance from the pipe to the booster so I wrapped the pipe with a double layer of exhaust wrap. You could also make a heat shield.
    firstinsteele and wvenfield like this.
  3. Happydaze
    Happydaze
    Much less than about an inch of clearance is pushing your luck somewhat I'd say. But thermal wrap on the exhaust in that area would help. Or you could move the exhaust some? And if you're changing the booster size to get more ***istance I'd suggest you step up to an 8" double to begin to really make a difference.
    Chris
  4. kbuhagiar
    kbuhagiar
    Thanks for the reply. I am definitely upgrading to an 8" dual-diaphragm unit.
  5. bobss396
    bobss396
    Eventually the heat still shorten the life of the booster internals. Can you do without a booster? Does your 7 year old sister or 95 year old grandmother drive the car?
  6. wicarnut
    wicarnut
    Wrap exhaust pipe and make a heat shield to avoid problems
    olscrounger likes this.
