frame question
Discussion in 'The Hokey Ass Message Board' started by hotrod 32 ford, Sep 28, 2012.
  1. What wheel base s-10 frame is used under a 1950 short bed chevy?
  2. 26 roadster
    26 roadster
    108.3, 117.9 and 122.9 are your choices
  3. brigrat
    brigrat
    from Wa.St.
    Some S 10 frames the side rails are "fitted" one inside the other with a weld. Cut/grind the weld and you can fine tune the wheel base length by telescoping them in & out and re weld.......................
    Lot's of info here ...... http://ad-engineering.com/HOMEPAGE.html
    A search on the HAMB, S10 AD, will provide lots more!
  4. falconsprint63
    falconsprint63
    from Mayberry
    buy a king cab or lwb chassis, drill the rivets and slide it to adjust to the wb you want
