frame tubing wall size
Discussion in 'The Hokey Ass Message Board' started by cliff bryan, Nov 12, 2008.
  1. cliff bryan
    cliff bryan
    starting my build and have access to 2"x3" tubing, 3/16" wall...using this for a t coupe with sbc, etc...I know it will work but do you dewds think this wall thickness is a bit too much...using heavy wall bones etc...tell me what you think. tia:confused:
  2. If you are going to buy then use 1/8" wall. But if it is free it is certainly worth considering. Figure a 50% weight penalty.
    And if you will be running some serious horse power or carrying big block/hemi weight 3/16 might be prudent.
  3. ange 33
    ange 33
    from over here
    wouldn`t use any thing less...
  4. I had the same question so I checked out what production frame builders are using and that is .120 or .125 wall. It didn't seem to matter if it was a tube frame or formed rails.
  5. scottybaccus
    scottybaccus
    We use either .120 or .195, so I won't tell you not to. If weight is not a concern, I prefer the heavier wall because it "feels" better. I like working with it and it seems to be more rigid, especially where you have less triangulation to stiffen things up.
