Technical Frame Width - newbie question
Discussion in 'Traditional Hot Rods' started by Kevin Vannoy, May 11, 2021.
  1. RICH B
    RICH B
    Hung a starter on that old 283 and it measures a bit less than 9-1/2" off the cranks center. Guess that would be no problem in a 20" frame. One of those new fangled late model starters would even give you more room. Not the best pictures; but should give you an idea.
    If you don't care for stock Chevy mounts; a Ch***is Engineering 17" mount set up would drop in place pretty good.
    Just Gary likes this.
  2. Marty Strode
    Marty Strode
    Back in the 70's, I built this T-frame with 20" centers, and the rails were parallel. Reason being, was the torsion bars hidden inside the rails. It did have a 289 Ford engine. img20161231_15371815.jpg
    Just Gary, RICH B and mgtstumpy like this.
  3. Kevin Vannoy
    Kevin Vannoy
    from WV
    Rich,
    Thank you for taking those measurements I really appreciate that! I was looking at the Trans Dapt 4100 mounts someone suggested yesterday and I’ll also check out the Ch***is Engineering mounts you suggested also. It is definitely good to know that the starter should fit and if I use an electric fuel pump as suggested yesterday it sounds like it’ll work out alright.
    Marty,
    That is a good looking car you have there. Do you still have it?
