Technical Frames Fabricated from Sheet Metal?
Discussion in 'The Hokey Ass Message Board' started by lake_harley, Jul 19, 2022.
  1. reyn
    reyn
    RICH B likes this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    10 gauge. (.140 ) the top is flat and the bottom tapers from the middle to the front and the back outlaw8.png
    21250F70-03C2-4335-B765-50F5EE3DCF3E.jpeg 4F53FB86-4DD1-4BE1-831E-26CAFB4789E0.jpeg
  3. Chavezk21 and Moriarity like this.
  4. lake_harley
    lake_harley
    WOW, Thank you reyn! That's not the thread I remembered seeing though, it's much better! It's much more detailed and complete and will require several read-throughs to grasp all of the steps. You can tell that building the frame was a labor of love by flthd31 who posted it. The fabrication skills and patience are certainly to be admired. It makes me want to build a frame from some of the sheet metal "drops" I have left from my fabrication business days even more. Good Winter project perhaps? Cost would be $0, other than cutting/welding gases and welding wire/TIG filler rod.
    Thank you.
    Lynn
  5. reyn
    reyn
    No problem. After seeing that thread I had to build one also. I love fabricating, but it is a lot of work, but cheap and rewarding.
    Reyn
  6. goldmountain
    goldmountain
    Be sure to check out Reyn's build thread too. Very impressive. I used the "c" section that Anthony suggested from Welder Series and they worked great in the kick up in the rear.
  7. This has been floating around in my brain
    would need access to an industrial shear and press brake.
    I’ve used an industrial shrinker/stretcher that would work 1/8 steel.
    The pieces could be contoured too fit a body profile.
    Access to a pulmax and ya could stamp some fancy details in it.
    or creatively wack it with a hammer a lot
  8. Ziggster
    Ziggster
    Nothing fancy, but I had a local metal shop bend me up some C channels out of 10 ga for my speedster project. The length (12’) I had bent up was pushing the limits of their press brake.
    anthony myrick likes this.
  9. lake_harley
    lake_harley
    It would indeed require something substantial to bend 12' of 10 Ga (.134"?). My 40 ton ironworker strains a bit to bend 15" wide 5/16"! I'd say 10 Ga. was certainly more than adequate for a lightweight speedster.;)
    Lynn
  10. saltflats
    saltflats
    from Missouri
    Check out a HVAC shop, the one down the road from my shop can bend anything I believe.
  11. RICH B
    RICH B
    At the truck shop plate started a 1/4".
    We stocked sheet metal from 16ga up to 8ga and plate from a 1/4" up 3/4".
    In the old days before plasma we had a big ol' Black & Decker (?) nibbler that would do 8ga (3/16).
    I've made Model A front crossmembers out of three pieces of 8ga. Also made repair sections for a '40 frame out of three pieces of 10.
    No reason you couldn't cut the profiles out of plate and jig it up.
    Saw a mag article about Just A Hobby rails and there was a picture of the guy using the same nibbler we had cutting out deuce rails.
  12. The37Kid
    The37Kid
    MILLER, Adams, and Stevens built INDY car ch***is using heavy gauge sheet metal, they came out good enough to chrome.
    dana barlow likes this.
  13. lake_harley
    lake_harley
    I have a Milwaukee nibbler that is rated to 10 gauge, and that's certainly all it wants. For what I have in mind, and what I have of leftover steel is 12 Ga. so the nibbler is up to the task but one really has to be careful to cut an accurate line with all of the vibration of the nibbler. IF I ever go ahead with the project I envision I might use the nibbler, but cutting with plasma cutter using a thin (luan plywood) pattern that's been carefully finished would probably make for more identical parts.
    Lynn
    seb fontana likes this.
  14. RICH B
    RICH B
    ^^^ plasma for sure now-a-days.
    Maybe it's just me; but I always ground the edges of plasma cut pieces, seemed it welded better that way.
  15. Marty Strode
    Marty Strode
    These rails were 100" long and ten gauge P&O, my brother sheared them, but his 70 ton press couldn't do the job. I have a friend with at least a hundred ton mechanical. IMG_3543.JPG IMG_3549 - Copy.JPG
    RICH B, anthony myrick and The37Kid like this.
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  17. EV34
    EV34
    I know what thread your talking about. I followed it and thought it was the great what he did and how he made it. I will keep searching but if my memory serves me right that was over 10 years ago that it was posted.
    thanks
    Ethan
  18. enjenjo
    enjenjo
    from swanton oh
    Miller frames were hammer formed over a cast iron form. If you wanted to do multiples you could make a steel hammer form, but up to 1.8" steel a hard Maple or White oak hammer from will work.
  19. Max Gearhead
    Max Gearhead
    from Wisconsin
  20. Blake 27
    Blake 27
  21. Max Gearhead
    Max Gearhead
    from Wisconsin
