Projects Frames
Discussion in 'The Hokey Ass Message Board' started by Ole tin 209, Feb 5, 2019.
  1. Ole tin 209
    Ole tin 209
    I have a 1929 body and I’ve seen Ford sedan’s like that be put on T bucket frames on line but is that possible.
  2. Anything can be done , doesn't mean it's always right. Put that A body on an. A frame or pony up for a 32 frame...do it right. PLEASE..... .Mitch
    Hnstray and upspirate like this.
  3. bct
    bct
    if the wheelbase was right... why not? but as said above the best frame is the one your body came with. around here a bare A frame is 250$ there is so much aftermarket support for them that it is the best option.
    upspirate likes this.
  4. scotts52
    scotts52
    A T frame isn't very strong with any kind of engine but a T or A engine. Unless you have a TT. Don't start off on the wrong foot. Start with at least an A frame or make one out new stock.
    pitman likes this.
  5. H380
    H380
    from Louisiana
    Figure out how you will get a title and register it before you spend any money.
    Hnstray likes this.
  6. Absolutely You can set that body on something like this.
    You'll need to add body mount brackets and tabs
    You could put anything on a simple frame like this
    milwscruffy and scott27 like this.
  7. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Check out Boling Brothers.com. they make A frames, they might have what your looking for?
  8. pitman
    pitman
    2 X 4 X 1/8th steel rect. tubing. Get (3) 10' lengths, and lay out to 'A' dimensions. A vee cut equal to 3 hacksaw bladewith midships will make the 'matched pair' of side bends.
    Curve the frame horn extensions w/sideface cuts, bend the top down to fill. You'll also want to cut & vee the frame horns so they end up parallel, if I recall correctly. :rolleyes:
    (approx. 2 days labor, plus cost of steel)
    For front X-member, lay it down, flush w/base, mount rad. on it. The mid & rear X-members are vertical to meet side rails.
    scott27 likes this.
  9. 1946caddy
    1946caddy
    from washington
    If going this way, here's all the dimensions you need. I did something similar but used a old Model A frame and cut off the front X member at the back and used the X member along with the frame horns and all the brackets.
    http://www.wescottsauto.com/WebCatalog/Tech/FrameDiagram1928-31.pdf
  10. lostone
    lostone
    from kansas
  11. If we are talking stock T frame for one it is a wiggly bastard and then the wheel base is too short ny about 3".
    Could it be done? Well beefing the T frame and stretching it in the rear are options but you would still have a sub standard setup. A deuce frame would be an upgrade and a T frame would be a down grade.
  12. WB69
    WB69
    from Kansas
    I wouldn't do it. As said by porknbeaner, very weak and short. A lot of work and still substandard. Just my opinion though.
