FrankenBlaster
Discussion in 'The Hokey Ass Message Board' started by 53choptop, Jun 6, 2008.
  1. Clik
    Clik
  2. Streetwerkz
    Streetwerkz
    It's cool that you made it, and it actually werkz!!
    good luck :)
  3. Uptown83
    Uptown83
    Whats wrong with using just sand?
  4. GizmoJoe
    GizmoJoe
    The "dust" from sand will cause silicosis of the lungs.
    Check out this link for some info:
    http://en.wikipedia.org/wiki/Silicosis
    Bad stuff.
  5. Clik
    Clik
    I'm actually waiting on the nozzle but I'll let ya'll know how it works. If the store bought pressure pots are simply bottom outlets and have no riser pipe in them it should be the same principal and should work just fine.
  6. 53choptop
    53choptop
    pm me if you want, I can "cough" send you the plans "cough"
    I had to upgrade to hardedned nozzles, the ceramic ones did not make it through the 1st bag of media.
  7. FlynBrian
    FlynBrian
    Awesome Thread. Going to start rounding up the pieces to build one, very Kool! Thanks 53choptop!
  8. i know this is an old thread but i saw someone asked for plans. check out www.vintageprojects.com some really bad *** old "engineering" stuff on there, as well as sandblasting plans. And a model T tractor!
  9. Clik
    Clik
    I built my blaster using a propane tank and the same basic principles found with this one at vintage projects http://www.vintageprojects.com/metal-welding/sandblaster-plans.html The tank I used was a little bigger than the size you use on a BBQ grill. Next time I'll use a bigger tank. My compressor puts out about 12 CFM/120 PSI and sits on an 60 gallon tank. It doesn't quite keep up but you just about run out of sand as you run out of air. As the air pressure drops you need to adjust the valves on the pot. It almost takes two people to keep things flowing well. Next time I'll buy the bigger air compressor. I bought my nozzle/gun through Amazon.com for about ten bucks. Buy two and get extra tips. I buy my blast media from Tractor Supply. I use the fine grade. Water in the air is an issue. It causes clumping. I run my air through a second air compressor tank as I can't imagine a small filter/separator doing the job. I live between the Pax River and Chesapeake Bay, so, it's very humid here. Keeping a garden hose misting the outside of the second tank helps dry the air.
  10. lawman
    lawman
    Thanks for the info. i would love to have one . Tom (tired Old Man)
