Technical Franklin quickchange.
Discussion in 'Traditional Hot Rods' started by sdluck, Nov 19, 2017.
  1. DDDenny
    Did you possibly call their customer service dept.
    I machined many parts requiring lock nuts, not 100% sure but seems some were left hand.
    I also ran the toolroom for many years and McMaster-Carr was one of our specialty vendors that had hardware that other vendors did not stock.
    Poh likes this.
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I have them. RHT are $10, LHT $15. Don't blame me.
    I have several used RHT but no LHTs that aren't chewed up. I think this is due to guys not knowing and beating the hell out them trying to go the wrong way.
    If you find a cheaper source, please let me know.
  3. Marty Strode
    Marty Strode
    I have bought them from Speedway Engineering.
  4. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Doesn't anybody want me to make a buck?
    weemark and Ric Dean like this.
  5. sdluck
    sdluck
  6. gimpyshotrods
    gimpyshotrods
    It would appear not.
  7. Poh
    Poh
    from Quincy,Ca.
  8. DDDenny
    Like this poh
  9. gimpyshotrods
    gimpyshotrods
  10. sdluck
    sdluck
    Just like that
  11. sdluck
    sdluck
    I went an mocked up the rear,it looks look the locker gears are closed together.I ***ume one axel takes a bolt in the end of it to **** up against the other axel to keep them from going to far in.
  12. sdluck
    sdluck
    I got the left handed axel nut and axel from an old racing buddy. gimpyshotrods and GearheadsQCE along with everyone else ,thanks for all the help The car and rearend are about 15 miles away where we are working on it.
    gimpyshotrods likes this.
  13. 4b316
    4b316
    from ny
    Did you get this together?thinking of putting one under my 46 dodge pickup.
  14. sdluck
    sdluck
    I am rebuilding my car,but the are not hard to redo,talk to GearheadsQCE he was a lot of help
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Tell us about your rear end!
  16. sdluck
    sdluck
    This is a offset frankland quickchange,it was never installed it was 60 inchs wide. With info from GearheadsQCE I removed the rs axel tube heated the bell up removed it cut 2 inches off reinstalled,drilled new 3/8 holes to put the bolts back in that help hold the tube. Bought another axel and the rear is now 58 inches.I am trying to get some different bolt pattern hubs mine are 5X5 I am looking for some 5X4 3/4. Car is a blown apart right now. Rear has full floating hubs.
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    SDluck,
    That's cool. I was actually asking 4b316 as to what he wanted. But you did an excellent job of explaining your setup. I think you are really going to like yours when it gets on the road again.
  18. 4b316
    4b316
    from ny
    we don't have one yet but am looking at several.we used to run one ourselves in our asphalt late model so pretty familiar with one.we will probably run a gold track in it.
  19. sdluck
    sdluck
    Gearheads ,What do you recommend after I have the welding done ,paint ,powercoat or what .My housing is mag.
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Are you thinking of coating the center section or just the steel stuff? I'm not a big fan of painting or coating magnesium, but I don't know why.
    Most of the QCs that I build leave here plain and the customer paints or coats to match.
    Sorry, I can't be of more help.
  21. sdluck
    sdluck
    What is the best stuff you have used for cleaning Mag? I talked to Rich Davis today and he said he has seen some axle snouts that were 2 5/8. You said you had some oddball ones that didn't fit anything, maybe thats what they were.
  22. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    sdluck.
    I just use mag wheel cleaner and polish, Never found anything that keeps the finish shiny.
    The oddball snouts I have are 2 1/2" but too short for the common hubs. You can put the bearings on but no room for the nuts.
    The 2 7/8" are fairly new on the scene. I have never had the need for anything that big. I suppose a Pro-Stock or Super Speedway car might need them, but then I would think that something else would be the weak link.
