Free Band Saw
Discussion in 'The Hokey Ass Message Board' started by hoarder1212, Apr 23, 2008.
  1. hoarder1212
    hoarder1212
    I have a friend that will give me a bandsaw for free if I want it. It is a meat saw from a butcher shop. Has anyone here ever converted one of these to cut metal with? I'm sure I will have to put better blade guides on it, but what else? Maybe make it variable speed with a step pulley?
  2. Unkl Ian
    Unkl Ian
    Your blades will last a lot longer if you slow the speed way down.
    Better guides will help.
  3. Do a search there was someone who posted specific instructions on how to do it properly. Good luck it's not the difficult.
  4. thirty7slammed
    thirty7slammed
    from earth
  5. Harms Way
    Harms Way
    There is a old guy up here that took a really beefy wood band saw years ago and geared it down with a transmission from a lawn tractor:eek:,...... he is still using it after like 20 years ! (strange but true).
    He said that with the wide variations in gearing, he can change blades, shift it into a gear from first to fifth and use it for just about anything.
  6. toddc
    toddc
    You can cut thin sheet ( up to about 0.060 ) with a worn out fine tooth blade at wood/meat speed. The sheet glows red at the cut, and the tooth profile draws air in to produce a thermal cut. Cuts really fast! The blades don't last very long - but if they are too blunt to cut conventionally its no loss.:)
  7. hoarder1212
    hoarder1212
    Wow thanks guys for all the helpful info. I will definitely be getting the saw.
  8. Rudgeman
    Rudgeman
    from New Jersey
    If anyone is interested I have a horizontal pivoting band saw for sale, never thought to list it on here. The one I have is made for metal, but it's not the upright type you guys are talking about. If anyone could use it send me a PM. I'm in norhtern NJ and I'll let it go cheap. Just thought I would mention it.
