Hot Rods Free hot rod motor if I go pick up another motor and some other junk and move it.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Mar 15, 2024.
  1. 05snopro440
    05snopro440
    Great find! So does it turn over? ;)
    Budget36 likes this.
  2. chevy57dude
    chevy57dude
    Great save, great parts score as well.
  3. wheeltramp brian
    wheeltramp brian
    Haven't tried to turn it over yet. It does have the two eighty three crank It does have the 283 crank. th-1999203947.jpg
    guthriesmith likes this.
  4. nrgwizard
    nrgwizard
    from Minn. uSA
    Huge pop-ups, tame-able w/E85. :D .
    Marcus...
    winduptoy and Balljoint like this.
  5. Balljoint
    Balljoint
    Great score! As squablow stated, take it all if you can, even if it takes some time to get rid of it at swap meets and giving some of it away, at least then it doesn’t go to the land fill or the recycling center.
    I’ve participated in a few ventures like this and it’s always entertaining, even of there’s work involved. It’s like a treasure hunt and detective work rolled into one.
    A friend of mine was asked to get rid of a small block Chevy that had sat under a garage bench for 30 years after their son had pulled it from a car and moved out east. He extracted the engine, took it home and decoded it. Turned out to be an original 302 out of a 69 Z-28. I think he paid them $25 for it.
    I responded to an add for a Pontiac 400 in the local newspaper about 20 years ago. Guy had it in his garage and I think his kids had worked on it but I never did get the whole story. He was asking $50 so it was a no brainer, I loaded it up and took it home. Engine turned out to be a 1974 low compression 350 from a GTO of that same year. Then it got interesting, cylinder heads were large chamber 4X heads, (I think somewhere around 114 cc’s). The pistons in the short block had some taper on the upper ring land, I suppose to reduce compression on a smog era engine. I’m not sure but I think those 350’s started out around 8:1 or lower, and with the large 114 cc cylinder heads the compression was lucky to be 7:1 if not less. I pulled the camshaft and it was an early 60’s McKeller solid lifter cam with lift and duration that were similar to a Ram Air IV. Lifters turned out to be hydraulic. I’m not sure what they were trying to achieve. I found a spun rod bearing so I ***umed that they couldn’t get it to idle with the horrible parts mismatch so they revved it to the moon to keep it running. Hard to say but it was an entertaining evening spent dis***embling someone else’s misguided attempt at performance.
    If you have the chance to invest in someone else’s car parts trove it’s usually time well spent.
    WC145 likes this.
  6. Marty Strode
    Marty Strode
    Thanks for that, makes it quick to identify.
    winduptoy likes this.
  7. bobss396
    bobss396
    I worked with a guy whose FIL rented out houses in the area. One tenant moved out and left a pair of SBC engines in the garage, full set up with an in-board Flagship Marine FWC set up. Plus the in-out boxes still attached. Likely they weighed in at #1200 each.
    He gave me the first offer to just get them out of there. Timing was no good at the time, so I p***ed. The engines looked like that were 1966-ish. Possibly 327s.
    Balljoint and winduptoy like this.
  8. swade41
    swade41
    from Buffalo,NY
