Technical Freeing up stuck mopar 413
Discussion in 'The Hokey Ass Message Board' started by johnfin, Jan 19, 2018.
  1. Earlier you said the cylinders looked good. Does the cam turn now with no chain? Lifters move?
    Not seeing the big picture here ,or any pictures for that matter.
    If you think it's the crank that's stuck ,then just pour about 3 gallons of ATF mix in it and let it soak. Then work the crank back and forth with a pry bar or breaker bar.
  2. King ford
    King ford
    from 08302
    Hey Johnfin, were the heads off when you started on this project as of somebody else was looking for a problem?if so it may have a spun bearing....good luck and let us know what you find!
  3. nrgwizard
    nrgwizard
    from Minn. uSA
    That'll work, too. Use large drip pan. :D .
    Marcus...
  4. PoRodder
    PoRodder
    from St. Louis
    IIRC the 413 has a rocker shaft ***embly on each head. I would certainly remove them before attempting to rotate the engine. It's just a few bolts to remove and eliminates the sticking valves /rockers from the problem. I got a stuck nailhead and there was no way it was going to rotate without removing the rocker shafts.
