Technical Freeze/Core plugs
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Feb 11, 2016.
  1. seb fontana
    seb fontana
    from ct
    Threads are pretty old so thought I would up date..SBF p*** side block, appear to be 1.5 x .375..I found the ways to get out and install and Groucho made mention of some type of br*** bolt in, be great for me cause I don't think I have the strength for a good hammer swing as engine is in car..I looked in Napa and could find hammer in style in br*** but tried for a while and could not find anything other than rubber expansion.. Could some one point out the latest and greatest currently available?
  2. squirrel
  3. seb fontana
    seb fontana
    from ct
    Neat! I think I can handle that style! Thanks Squirrel!
  4. seb fontana
    seb fontana
    from ct
    My luck local O'reilys dosen't have, they'd have to get out of TN! and shiping..Napa only seems to do Doorman; only expansion are in rubber..
  5. squirrel
    At least now you have a part number.
  6. seb fontana
    seb fontana
    from ct
    Yep. thanks..Up date: went to Napa to get br*** pound in but took the pic of what Squirrel posted and they crossed the Doorman number and came up with,,Plug t nde 600-4027 of which they had the three I needed..$4.99..I'll put some permatex #2 in stratigic places and put them in..Made in China [of course]
  7. Summit has them for 6 bucks.
  8. Budget36
    Budget36
  9. squirrel
    I used one once, in an engine that had a slightly oversize hole, and no solid plugs would fit the hole. It worked ok.
  10. 38Chevy454
    38Chevy454
    I learned something today, never seen the expanding copper plugs before. Knew of the rubber ones, but never had seen or heard of the copper one. Will file that in my ever-increasingly crowded memory. The filing part works well, it is the recall portion that is the tough part!
    RICH B likes this.
  11. seb fontana
    seb fontana
    from ct
    Put them in..No built in stop to how much to tighten so you have guesstamate . Used a big nut with the chamfer of the plug hole to get uniform depth..Called copper but are magnetic..
  12. seb fontana
    seb fontana
    from ct
    Part number would be helpful
  13. Mr48chev
    That's a new one on me but could be a life saver when you have one leak and aren't close to the home shop.
  14. 02482
  15. 5brown1
    5brown1
    They are not always easy to install with the engine in the car. If I were to use them again I would use a product like Perfect Seal #4 which gets very tacky in the hole. Then install the plug but not tighten until the sealant has time to set up a bit so they will stay in place. A 17mm wrench, IIRC, can be used to keep the plug from turning when tightening the nut. I also found that you only tighten the nut two turns - again IIRC. I am always amazed that many auto parts mfgs. can't provide any instructions with their products.
  16. squirrel
    might also want to buy two of them, in case the first one gets messed up while you learn the above instructions :)
  17. Slow down
    Slow down
    Freeze plug rusted out in in the wife's winter beater with a sbc , popped it out and put in a block heater easy fix . Up here all parts suppliers stock them . A second block heater helps when it's 35 degrees below zero F.
  18. seb fontana
    seb fontana
    from ct
    I do summit search and doesn't come up...Trying to remember how many turns I tightened the nut, would be nice for positve stop or maybe when the threads of the bolt bottom out in the acorn nut is it?
  19. Summit Racing Part Number: RNB-02482
  20. seb fontana
    seb fontana
    from ct
    That works, thanks..
