Technical French flathead with TH 350
Discussion in 'Traditional Hot Rods' started by Spirescu Andrei, Oct 23, 2021.
  1. Spirescu Andrei
    Spirescu Andrei
    Hello,
    I am looking for wisdom . I bought a french flathead and I am dreaming to put a TH 350 on it.
    Problem is there are no adapter kits available for obvious reasons.
    My question to you all is:
    Can you mill down the engine block to the extent that it may accept early style bell housing?
    Or anybody has done this before? Any input other than: “ you are on the wrong path” would be highly appreciated.
  2. gimpyshotrods
    gimpyshotrods
    Why would you mill down an engine block to adapt a transmission?
    Just build an adapter. The Chevy pattern is online as a blue print. A good machinist can pattern the block.
    A couple of chunks of aluminum and you get two adapters. One for the block/trans, and one for the crank/flexplate.
    Do it right and you can drive a Chevy flexplate with a straight-bolt Chevy starter.
    Stogy likes this.
  3. gimpyshotrods
    gimpyshotrods
    I'd be more inclined to get a Ford C4 behind it.
  4. big duece
    big duece
    from kansas
  5. gimpyshotrods
    gimpyshotrods
    The French flathead, if memory serves, does not have the later-style pattern that this kit is for.
    I believe it has what is close to the earlier style.
  6. big duece
    big duece
    from kansas
    duncan and mgtstumpy like this.
  7. gimpyshotrods
    gimpyshotrods
  8. Spirescu Andrei
    Spirescu Andrei
    Glad you all figured my issue…
    Now back to original question if I may.
    Can it be done?
    Has anyone done it without destroying the block?
  9. gimpyshotrods
    gimpyshotrods
    No.
  10. Flathead Dave
    Flathead Dave
    from So. Cal.
  11. Flat Roy
    Flat Roy
    Ford Barn says C4 is great. I have a flat-o-matic converter and beefed up C4 behind my Supercharged 8BA
    and it's GREAT. Been driving it around for over 10 years now.
  12. Spirescu Andrei
    Spirescu Andrei
    Thanks for your input.
    On the hunt for a C4…
  13. indyjps
    indyjps
    Are you outside the US? There may be trans options that are more common in your area. Having access to a good machinist or equipment would be the key to making it work. Good Luck.
    gimpyshotrods likes this.
  14. RICH B
    RICH B
    Now you are on the right track; why re-invent the wheel when there is a good solution already available.
  15. sloppy jalopies
    sloppy jalopies
    had a c4 behind my 265 -8ba ... chirped second gear almost every time...
    ****** buddy tweeked the band pressure... lots of fun...
    RICH B, big duece and gimpyshotrods like this.
  16. krylon32
    krylon32
    from Nebraska
    Use the Flatomatic kit, you won't be sorry.
  17. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    No matter which kit you choose, any auto trans takes more power(slippage) than a manual trans to push the car down the road!,! At least that is what I have been told—-the hamb “professionals” will either back me up or tell me I am wrong!!
  18. 2Blue2
    2Blue2
    I wanna see pictures when your done.
  19. Garpo
    Garpo
    There are always other options. I used a Flatattack (Australia) adaptor to use a Toyota 4 speed auto; (top is overdrive).
    I love it. The Flatattack kit is excellent.
    I am using a 3.9 ratio rear gives 2000rpm at 60mph with 195/80 x 15 tires. Possibly 4.0 rear would improve it?
    Which ever auto you choose think carefully about the combination of engine tune, car weight, gear ratio, tire size etc, and be honest about how it will be driven.
  20. bob miller 32
    bob miller 32
    from france
    flat o matic with C4 ! it's made for
