Frenching 1940 Chev Head Lights
Discussion in 'The Hokey Ass Message Board' started by 27 tallt, Feb 1, 2013.
  1. 27 tallt
    27 tallt
    Has anyone frenched their headlights, by any other method, other than using the Hagan kit?:confused: I have their kit in place and it is awful.:mad: The rings are held on with 3 clips and when one leans over the car to check the rad, or whatever, the ring moves and at times has popped off.:eek: I would like to french the headlight (something like using the '52-'54 Mercury rings which would give me a tunnel effect) and eliminate this problem. Any ideas as to what I can do would be greatly appreciated. I would ***ume that the headlights of the late '30's and even the late '40's would almost be the same. Searched the archives and most of them relate to doing a '53-'53 Chev.
  2. rusty1
    rusty1
    ...those headlites go in from the front; most frenched headlites go in from the rear;...this wouldn't work on your 40 unless you unbolted the headlite buckets from the fenders to do so; or you cut out the fender below.
    You'd have to make em so you can mount the bulbs from the front, then install a trim ring that looks frenched.
  3. Bagged50Buick
    Bagged50Buick
    Rusty is right.....you may be able to unbolt it from the fender and go in from the bottom. I think the conical shape will not allow it though.
