Technical Fresh flathead locks up when warm
Discussion in 'Traditional Hot Rods' started by douglasb, May 10, 2022.
  1. I agree, a used engine is a core engine.
  2. My Buick looked like that after overheating badly.
    Ben
  3. Just gotta throw this in here for the sheer joy of education, along with a little entertainment, I have a friend that was in the dump truck business for years. He owned quite a few of those trucks with the 427 tall deck engines, bust most of his stuff was GMC Brigadier with Detroit diesels. Well for whatever reason he had to put an input shaft in the transmission of one of the gasoline trucks. Next thing you know, the engine locks up. He runs to the Chevy dealership in Winchester and gets a short block, throws it all back together, and it locks up, he calls the Chevy place, they apologize and tell him to come get another short block, and they will throw in the gaskets and whatever, so he does it again, and this one locks up. He calls the Chevy place again and the parts guy has a little light go off in his head, he jumps to work and figures out that it's the wrong input shaft! Little too long, causing the thrust bearing to lock up! They gave him a new input shaft, new long block, and when he asked what they were gonna do with those short blocks, they gave em to him. He ordered new main bearings for them, and put them under the bench :D
    AHotRod and 41 GMC K-18 like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    this confuses me, the piston in the earlier picture when the engine was still together clearly is stamped std on top. How can a std bore engine be too tight? were some of the pistons changed with new ones that might have bee made too big?
  5. perhaps it was sleeved and is underbored?
    osage orange and Moriarity like this.
  6. john walker
    john walker
    Nope, gonna need a bore job and new pistons. Don't waste any more time trying to clean that mess.
    AHotRod, 41 GMC K-18 and jimmy six like this.
  7. lippy
    lippy
    from Ks
    Looks like it was drier than a popcorn fart.
    AHotRod, seb fontana and Tman like this.
  8. Budget36
    Budget36
    I wonder if someone went over board with Bon Ami to seat rings?
    Tman, 51504bat and Dan Timberlake like this.
  9. Flathead Freddie
    Flathead Freddie
    Fresh Flathead yes a little too fresh to be having this issue and you need to know it's ***embly history and drill that guy so you know what he may have missed . Engine needs dis***embling and start FRESH again with an individual parts inspection gosh could be as simple as mismatched piston ***emblies it's a common some mistake . Hope your crank is still good and no burn marks so also ring gap and well just start over again and seizing the engine multiple times puts strain on those beautiful 7" connecting rods . Take it to the machine shop is my professional answer and start like its a seized engine which of course it is. . I don't wish you good luck on this I wish you take it to a qualified machine shop . If you wanna do it on your own and you get frustrated enough I'll buy the mess from you for $250 . Gosh
  10. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Bummer.
    I raced karts for years and used straight hydrochloric acid to removed aluminum from cylinder bores. I didn't stick many of 'em but it happened more than once. Works cleaner (looked it up) main ingredient is acid, so I learned something new today. Thanks SS. Looks like you have a cobbled together POS someone called a fresh rebuild. Cobbling is not rebuilding.
    I hope I'm wrong but the cylinder scoring looks like overbore time. Just a guess. Let us know what your FH spe******t says.
    SS327 and 41 GMC K-18 like this.
  11. 41 GMC K-18
    41 GMC K-18
    F = FLATHEAD
    R = REBUILT
    E = ENGINE
    S = SEIZED
    H = HOSTILITY !
    That really ****s, that the engine wasn't, ***embled properly, but then again, there were some major unknown's about it right from the beginning.
    Caviet Emptor, ( Buyer beware )
    SS327 likes this.
  12. Budget36
    Budget36
    I don’t know about getting aluminum remnants of the pistons out of the bores, but would a brush hone clean them up enough to check taper?
    Like @Moriarity mentioned why would a standard bore piston seize up?
    Could be a home done job with sleeves and not sized, I dunno?
    Moriarity likes this.
  13. douglasb
    douglasb
    Thanks all after talking to my builder the pistons are .60 over but have std on them. So going to pull the motor and see about getting it oversized.
    Tickety Boo likes this.
  14. SS327
    SS327
    That ****s! But doesn’t the machinist have mikes to measure pistons and bores? Don’t go back to whoever built that engine. If those pistons are .060 over they should not even be able to go in the bore let alone move once the got em in!
    427 sleeper and gary macdonald like this.
  15. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Ive had a motor too tight on ring gap seize when warmed up.
    I agree these two things are your culprit and things that need addressing.
    Edit, saw the photos... Down right amazing someone put that together and sent it out the door like that.
  16. gary macdonald
    gary macdonald
    I don’t understand how std or even .060 over can be so close to the head gasket . Does you flathed guy know this is a 255 merc ?
    .060 wont fit in a std bore but .006 might , if you had enough taper , this is what would happen . IF , IF and more
  17. gary macdonald
    gary macdonald
    Whats inside the piston , any name ?
  18. seb fontana
    seb fontana
    from ct
    ?? If the piston is forged and maybe installed with stock clearance? A mess for sure.
  19. 34 5W Paul
    34 5W Paul
    from Fresno CA
    If the pistons are stamped STD and mic out as .060" over then I'm stumped. Crazy. And no, there's no way in creation even .020" pistons would fit in even the most worn out standard bore. No chance. Eight nine thousandths and they are flopping around in the bore.
    SS327, 427 sleeper and Moriarity like this.
  20. Daniel Dudley
    Daniel Dudley
    That block looks pretty good with the exception of the bores. At least it looks real clean from here.
  21. 6sally6
    6sally6
    Just a tad off-topic but.....has anyone ever found a subs***ute for those big old oil can sized pistons with the long skirts?
    I wonder.......if a subs***ute was found and, the engine re-balanced because of the lighter pistons, if the flattie would be bit more high reving?!
    (ain't that what hot rodding is all about?)
    jus wonder'in.......
    6sally6
  22. Truckedup
    Truckedup
    30758357631_ede5e2dd42_c.jpg Cl***ic four corner seizure...lack of piston clearance most likely in this case.....It can also be caused by detonation from too much timing or lean fuel mixture or overheating...
    A bike photo but it applies here...One of my vintage racers, detonation caused four corner seizure at high rpm....Looks like the flattie piston...I saved the cylinder with a honeing but gained a bit more clearance..
    Tman likes this.
  23. spanners
    spanners
    Maybe they are are std for another engine, just not this one.
    G-son and Wanderlust like this.
  24. Joe H
    Joe H
    Didn't they use to knurl pistons to tighten up the clearance? There are a lot of marks on the piston of to the sides.
    Budget36 likes this.
  25. douglasb
    douglasb
    Well the engines our and at the builder to be gone thru and punched out. Thanks all for the thoughts and comments.
