Technical Fresh Rebuild Clacking
Discussion in 'The Hokey Ass Message Board' started by DaneAmerica, Sep 18, 2023.
  1. DaneAmerica
    DaneAmerica
    Hello!
    I just got my 1966 Buick Special Deluxe Hardtop with 4.9 300 v8 on the road after getting the motor rebuilt.
    Parked For 45 Years: 1966 Buick SkylarkBarn Findshttps://barnfinds.com › 1966-buick-skylark-barn-find
    After setting the timing way wrong and driving a few blocks to the muffler shop, it is clacking from the p***enger side of the motor. I hear it when I jab the throttle while cruising or at about half throttle or more. I reset the timing confirmed good now and the clacking remains.
    After reading some posts here, I gather detonation is bad for the top of the piston and ring lands but that's about the only damage it can cause... my gut says it's not detonation I'm hearing but something mechanical. Could my machine shop be to blame.
    Should I pull off the intake and verify if the lifters are good? Call the engine builder? The pushrods are all straight except the ball end of one has a circular score mark. I have break in fluid in there now, a buddy of mine suggested a lifter could be empty... would filling up with the 20w50 I plan to run do anything to fill a lifter or is that something I have to do manually?
    I appreciate any suggestions y'all..
  2. jaracer
    jaracer
    You sure it isn't an exhaust leak on the p***enger side?
  3. Nailhead Jason
    Nailhead Jason
    or an exhast pipe hitting the frame or floor? that can and will sound like a knock in the motor
  4. The 2 comments above are in line, I'd check them. However, it sounds like you really don't know what an internal problem would sound like even if you could pinpoint where it's coming from. Your best insurance and for your investment is go talk to the motor builder and ask him to come listen. He will know if it's his problem of something you did or didn't do right. With his input you will go straight to the issue and take care of it. Driving the car a few blocks to a muffler shop with the timing a little off isn't going to cause a terminal inside issue but left unattended it darn well could. Your Ear and best Quess isn't going to fix anything. Protect your investment, do the right thing.
  5. DaneAmerica
    DaneAmerica
    I checked the manifold bolts are tight... but I didn't look at the new exhaust.
    So it's probably not mechanical huh
    That's what I'll do, I need the right set of ears on this sound..
  6. You're still guessing.
  7. If the engine has a heat riser valve on the RH side exhaust, when they are worn they can make a sound that sounds a lot like something bad happening inside the engine. With a good pair of welding gloves, holding the valve weight usually will quiet the noise enough to tell if that's the problem or not.
    gungeey, BJR, GlassThamesDoug and 2 others like this.
  8. Bandit Billy
    Bandit Billy
    I always start at the newest stuff I put on the car and work backward when chasing an issue. "New Exhaust" doesn't mean great exhaust.
    BJR and DaneAmerica like this.
  9. DaneAmerica
    DaneAmerica
    I did't put the heat rise valve back on..
    How overpriced the exhaust was, I couldn't imagine there could be a leak.. how silly of me!
  10. ekimneirbo
    ekimneirbo
    How did you determine that the pushrods are straight and one is scored ? Not a put down, but from your descriptions of the problem it appears you have very limited experience with mechanics. If you have loosened all the rocker arms and removed the pushrods, you probably need to get someone to show you how to re***emble them, because you have to rotate the engine to a certain (and different) point when reinstalling. I would check your oil to see that there are no metal particles in it if you are breaking in an engine...especially if you replaced the lifters. The "clacking" noise could simply have been a loose rocker arm or a stuck lifter......or as bad as a ruined camshaft during the break in process.
  11. chicken
    chicken
    from Kansas
    If the noise only occurs when you jab the throttle or at half throttle or more under load, lifters are not the problem. Exhaust leak is highly likely.
    RodStRace and DaneAmerica like this.
  12. DaneAmerica
    DaneAmerica
    I am way past being offended by constructive criticism haha!
    You guys rock, this is exactly the type of info I was looking for.
    If an exhaust leak is highly likely, I will hunt it down.
    If all else fails, I'll get some expert ears on it
    26 T Ford RPU likes this.
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    We can refer to possibilities but get someones ear on it.
    The builder is the man.
    If timing is ever off, that should be dealt before mufflers IMHO
    RodStRace and ekimneirbo like this.
  14. Bandit Billy
    Bandit Billy
    One side of the heat riser is flat where is seals to the manifold, the other side is relieved to fit the donut gasket. With it the donut has no place to seat on the manifold. Reinstall it with a flat gasket and new donut.
    DaneAmerica likes this.
  15. Budget36
    Budget36
    Maybe make a video so you can play the sound. Host it on YouTube and paste the link here.
    49ratfink and ClayMart like this.
  16. alchemy
    alchemy
    After you installed the engine, what break-in procedure did you do before you drove it to the exhaust shop?
  17. DaneAmerica
    DaneAmerica
    I think this is the solution... Now, let me see if I can find it!
    05snopro440 likes this.
  18. DaneAmerica
    DaneAmerica
    I have been following the word of the 1966 Ch***is manual off teambuick website. I did pre-timing based on the manual finding cylinder 1 etc. and it fired up, held it at 2000 rpm for about 20 minutes. I believe break in was successful..
    Now that I think about it.. I first heard the sound on the way home from the muffler shop...
    Will report back once I get the heat rise valve back on with proper gaskets.
    Bandit Billy likes this.
  19. alchemy
    alchemy
    A good exhaust guy shouldn’t have left a gasket out of the manifold to pipe connection, even if it wasn’t as the factory designed it. If that seems to be the problem, they should fix it for free.
    chicken and DaneAmerica like this.
  20. bobss396
    bobss396
    Exhaust leaks will leave a grey sooty residue, look around for that. You could have an undetected crack in the exhaust manifold. This is how I found a few of them.
  21. vtx1800
    vtx1800
    What you described as "clacking" reminded me of the sound I was hearing on the fresh motor in the car I was finishing. Check to insure a rocker adjusting nut hasn't backed off allowing excess clearance. In my case it was a flat cam:( I hope you don't have the same issue.
    DaneAmerica and ekimneirbo like this.
  22. 1971BB427
    1971BB427
    from Oregon
    It's cheap insurance to unbolt the exhaust manifold and look at the gasket that goes between it and the heads. It will reveal if there's a leak there as you'll see black sooty areas migrating out from the exhaust ports.
    I've seen guys pull valve covers, and even swap out lifters because they heard a "lifter rattle" and it was an exhaust gasket.
    As for the choice of 20w-50w oil after breakin, I'm wondering why you want oil that heavy? That's maybe OK for hi performance engines that see heavy, high rpm runs, but for a daily driver fresh engine it seems a bit much. Did your engine builder recommend this weight oil?
  23. rc57
    rc57
    Check for loose pushrods. I did a motor in a truck years back, ran great. Sent in for exhaust, ran like **** and noisy when it came back. Turns out they must have been testing out my gl*** packs and bent 3 pushrods on an over rev.
    Couldn't prove it and they wouldn't admit it.
    ekimneirbo likes this.
  24. alchemy
    alchemy
    If an engine is built right, why would revving it up bend a pushrod?
  25. Hitchhiker
    Hitchhiker
    I'd be looking at lifters and wiped out cam lobes
    Lloyd's paint & glass likes this.
  26. ClayMart
    ClayMart
    Where are you located? Maybe there's a HAMB member near you who could lend an ear.
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Probably trying to get an alleged " high zinc oil"
  28. BJR
    BJR
    A cracked flex plate can make some strange noises.
  29. Mr48chev
    Usually they make noise when there isn't a load on the engine as does loose torque converter bolts. I got the Olds 350 R that I ran in my 51 Merc for free along with the 60 something square truck it was in because it had a knock. The knock was loose converter bolts.
    Now with that behind, what I intended to suggest is go to the parts house or harbor freight and buy a Mechanics stethoscope. They work real well to isolate mechanical noises to a certain area/spot. Usually under a well spent 10 bucks.
    RodStRace, ekimneirbo and BJR like this.
  30. 1971BB427
    1971BB427
    from Oregon
    Never a good idea to begin troubleshooting by looking at the most expensive repairs! It's just common sense troubleshooting to begin with the easiest, least expensive problems, and work your way up. Starting with things like cams that can go flat, or other expensive, time consuming fixes usually results in a lot of wasted time and money.
