Technical Freshen up my 390 FE
Discussion in 'The Hokey Ass Message Board' started by wood remover, Dec 12, 2022.
  1. Broke my 390 ,tore it apart, and now to hopefully buy the pieces to put it back together, long story short ,piece of broken pushrod cup got into the cam and distributor gear and broke the oil pump drive .Shut it down pretty much right away but there is some galling on the crank and bearings that I hope will polish out ,will find out this week .Crank is already ground 10/20 .Found a std/std 390 crank that may polish .
    If I have to use another crank does it mean rebalance the assembly again ?? Also what bearings ,haven't been to the machine shop yet so looking to be informed when I do later this week I hope .
  2. It sheared the roll pin on the distributor as well ,but being standard rolled to a stop tried to start it , didn't know what was up till I pulled the distributor cap off and the rotor wasn't turning ,flatbed home ..
  3. An oem crank will not require a rebalance. There is a good assortment of bearings available and a variety of prices.
    wood remover likes this.
  4. Been looking at the sealed power 3/4 groove main bearings
    Clevite 77 p rod bearings with grooved upper shell.
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    A call to Don Palmer in Georgina will answer all your questions.(Near Orillia)
    On of the Best FE men I have ever encountered.
  6. Don't think very highly of Don Palmer !! Wouldn't recommend him to anybody.. not that he doesn't know Fe's !!!
    Thanks Jeff
  7. MeanGene427
    MeanGene427
    from Napa
    Take a look at the flange that the distributor shaft goes down thru to check for breakage. A 390 is a very easy engine to repair/ rebuild, and since you need a crank, you could easily upgrade to a 410/416 while it's apart. I know most of the FE "majors", never heard of Don Palmer. Also, an FE crank can run at a pretty big undersize, if you can find bearings to fit
    Boneyard51 and wood remover like this.
  8. Just looking to get the motor put back together as cheaply.as possible , ran strong ,actually going to detune it more for the street. Was running a 680 ? Lift solid roller cam , 1961 hp block , not drilled to run hydralic
  9. Sounds like it started life as a 375 Hp 390. Those came stock with a Factory aluminum intake, dual point dist. and a Holley carb. Most also had the shorty cast-iron exhaust manifolds. Those were pretty good for there day.
    wood remover and vtx1800 like this.
  10. Actually came with shorties and tri power,rated at 401 hp
    ffr1222k likes this.
  11. sunbeam
    sunbeam
    Remember when ordering the cam there was a timing gear change between 1962 and 63
  12. The cam was dealt with when the engine was last done ,originally a spring and button
