Fri nite tune and test
Discussion in 'The Hokey Ass Message Board' started by redlineracer42, Sep 29, 2012.
  1. Gettin ready for Run What ya Brung @ Cordova last nite....This clutch p.p. set up was supposed to be good for twice the power I am putting to it so W.T.F. ???
  2. dirt t
    dirt t
    I guess they were wrong.How many runs on this set up? Looks like fatigue on pressure plate.
  3. rat nasty
    rat nasty
    man i feel your pain my stuff is broke right now as well and i really havent been that hard on it one day i'll get it all lined out just gotta keep plugin away! my bearing retainer to my jerico keeps swelling to were you cant get the T.O. bearing off it they say its from bell housing misalignment ive got one of those fancy browell bell tools and jerico says dont trust them and to still dial indicate the bell off the crank? also says to chuck the trans mount dont need it with front and mid plate on the motor...over engineering has once again bit me square in the azz! ohh if its strictly a drag car go to a mc cloud soft lock they are great! or a lil higher but talk to Tim Hyatt he does speacial race clutches very well known! also look at UMTR.com for advise bunch of knowledge and good guys!
  4. Ya Tim has helped me in the past! I have already been in contact with me several times in the last 1/2 hour! I am gonna send it too him tomorrow I hope! He is a GOOOD MAN !Very helpful and sharp!
  5. LOTS OF RUNS! I run this on the street as well!
  6. SKULL ORCHARD
    SKULL ORCHARD
    from KS
    This TIM that you are speaking of is he a clutch salesmen ? if so i have some questions about what set up to use. thanks mark
  7. rat nasty
    rat nasty
    this may or not be per the rules but heck why not? Tim needs to be recognized he is prolly the best http://hyattracingservices.com/
    even though I dont use his clutch he would deff be in the line up if my local guy didnt do me right! I run a Ky. clutch dual disc "very brutal" not that hard on the leg either! very good work as well!
  8. MRTS33
    MRTS33
    Somebody forgot to tell the clutch. :D
    Bummer man!!!
  9. Tim Hyatt yes he has a big semi and follows the NHRA circuit.Top shelf clutch man!
  10. Tim tells me these plates crack at the rivet...Still had plenty of meat left but broke in the waterbox.
  11. swade41
    swade41
    from Buffalo,NY
    ouch, glad just the car was injured
  12. Thanks! My ****tershield took a couple dents but man what a racket!
  13. Yes Mark he is. Hyattracingservices.com I am sending my blown up parts to him at the next race and he is gonna fixem and sendem back right away! R~R
  14. MRTS33
    MRTS33
    Well better there than halfway down the track.;)
  15. indeed!!
  16. Dan Timberlake
    Dan Timberlake
    Is it a multi disk clutch? Is the stud mounting something provided by the clutch manufacturer? It looks like the PP/cover was sitting on washers, not clamped directly to the flywheel.
    in picture 2 it looks like there is a hole torn out of the clutch cover the size of washer under the flywheel nut, and the one on the other clutch cover/PP lobe has worn about halfway through the cover.
    I'm wondering if the nuts/studs got loose due to the clutch cover wiggling atop those stand-off washers and embedding into the clutch cover.
  17. No it is a single sintered iron disc.The .020 shims(washers) are used to set up ring height and you remove shims as the clutch wears.The hole torn out of the pressure plate is from my gently prying it with a bar as there was no other way except torch or grinder that this was gonna come apart after that violent clutch explosion. I have been in contact with my clutchman Tim Hyatt and my parts are on the way to meet him at the next race Friday.He says the plate I was using has been known to crack around rivets. This info coincides with my thoughts gained after dismantling and sifting thru shrapnel...I ***ure you,the clutch and related parts were correctly installed...Iv'e been fiddlin with this sorta thing very close to 40 years now...oh and yes the studs and nuts,shims all needed hardware to correctly install p.plate can be had inna kit form from Ram
  18. SKULL ORCHARD
    SKULL ORCHARD
    from KS
    thanks for the info men, i will contact him when money is good.
  19. BadgeZ28
    BadgeZ28
    from Oregon
    I am sorry about the carnage. It is probably wrong to rate clutch and pressure plates by horsepower. It comes down to how much weight and rubber on the rear. What I mean is the impact exerted on the hit. But how do you state that as a specification :D
  20. Kind of what I was thinking ^^^ only you said it better.
  21. I just mentioned that as a very broad statement to allude that the setup should have been way strong enough.
  22. Well,I did my homework...What do you base your opinion on please educate me...
  23. Can you explain where you are coming from?
  24. Looks like the pressure plate got loose.
  25. rat nasty
    rat nasty
    may just need to pull it out and inspect more often? I always hear most of the stick racers using a feeler guage to check wear also i drilled a hole to check depth in my bell & its used to adjust presure?
  26. I have inspected the carnage and I can see on a part of the clutch plate that came off,a crack that is darker than the break.It is tellin me the disc cracked by the rivet.Tim Hyatt a professional clutchman and took one look and said "those plates crack around the rivets"I have sent the shrapnel off to Hyatt Racing Services as that is his entire buisness and he is THE clutchman at NHRA events.He is gonna rework my flywheel, overhaul my p.plate and get me all hooked up right away! Service with a smile!
  27. Yes I have a factory hole on the bottom of my can so I can fit a feeler guage to check my airgap. I also drilled a hole in between my trans bolts to access my p.plate spring tension. the clutch was out for inspection last winter and I saw no cracks anywhere...I will inspect it a lot closer from here on out! I have faith in Tims judgement and will do what he suggests.I know there are clutch cars out there with 3 or 4 years on their stuff but inspection is yer friend!!!!
