Friends need your help piston rings 235
Discussion in 'The Hokey Ass Message Board' started by Rustem, Jul 9, 2012.
  1. Rustem
    Rustem
    Friends need your help! I bought a set of piston rings for the engine 235. There are three types of rings.
    1. Oil ring
    2. Rectangular
    3. slant angle and point at the top. (Taper)
    Question? How to set the ring first, and how to install the second. How to put Oil ring I know.
    Thank you.
  2. Baumi
    Baumi
    Install the Oil ring first, after that the second one and the top ring at last. The point mark on the top ring needs to face to the top.
    I hope that helps!
    Chris
  3. Rustem
    Rustem
    What is the top ring? Rectangular ог slant angle and point (Taper)?
  4. Rustem
    Rustem
    I have a ring in the form of a rectangle and a ring with a point, I think, too, a rectangle. What is the first (upper piston), which the second (in the middle of the piston)?
  5. Ole don
    Ole don
    Did you read the instructions that came in the box? After fifty years of building engines, I never opened a new box of rings with no instructions inside or on the box.
  6. Rustem
    Rustem
    The box says only how to install the piston, and in what sequence to set the ring, not written. Excuse me, I live in Russia, it is difficult to translate the technical language. By this I ask for help. I am writing with an electronic translator. :(
  7. squirrel
    does this help? You probably have the Torsional and Reverse Torsional type rings.
  8. Rustem
    Rustem
    Thank you friends! I had an argument with the mechanic. The instructions in the box was not.
    We do not know how to use it.
