Hot Rods From Troubleshooting Wiring to Ignition Hell
Discussion in 'The Hokey Ass Message Board' started by osage orange, Aug 2, 2025.
  1. Rocky
    Rocky
    Classified Editor
    Good plan.
    I was working as a line mechanic in the 70s for a Ford dealership and one day I had to change a turn signal switch in a T-bird. Cut the wires at the plug and pulled 'em out .......went to the parts dept and got a new Ford switch. SURPRISE! all of the wires were completely different colors from the original. I didn't make book on that job but I invented some new cuss words.
  2. G-son
    G-son
    from Sweden
    Aren't you forgetting that the losing side were using points ignitions too? Someone having won with points is hardly a selling point when the other half of the users lost using the same.
    The statistics gets even worse if you went to the race track back in the day, the winner would have been running points, but everyone else were also running points and there were far more losers than winners, so statistics say running points is more likely to make you lose. ;)
    Anyway. Points ignitions work, most of the time. So should other types do, but when there are issues in those they may be harder to pinpoint.
  3. LOL. Now that is a good explanation.
    I find MOST of the time my unsolvable problems are looking me in the face every time I look in the mirror.
    Ben
  4. RodStRace
    RodStRace
    I've got a comic card I bought in my 20s still sitting next to the bathroom mirror.
    osage orange likes this.
  5. Well, guys, got the 1970-era points distributor and coil Friday and spent most of the day ripping out the Duraspark II fiasco and re-wiring old school. The results at first weren't promising.
    I've hit a roadblock in changing over the wiring. I can't figure out what still needs to be done yet, but it's come down to the 4/5 connector wires from the Duraspark II system that I've got to remove/terminate/reroute. I also had a hell of a time rolling over the engine to exactly TDC. I can't get a straight shot at muscling the engine once the starter spins it close. No room to fit a socket and breaker bar onto the crank nut and since it is a fresh, yet-to-be-started engine, it's tight! I wired up the new ignition, turned the key and got nothing. I figured my distributor was too far out of time to light.
    Sat down to think about all that I did today. Couldn't logically think of anything I did wrong. Decided to go out one more time, put on the timing light just to see how far off the timing is. Turned the key to start and VROOOOOOOM!!!!!
    I about **** my pants!! It went off like a AA fuel dragster (gotta adjust that idle) and roared (no muffler! Damn, it's LOUD!) So I'm calling it a night with a big grin on my face. I'll sort out the idle and timing (didn't run it longer than about one full second but now know I'm damned close to 10 degrees BTDC.
    My thanks goes out to all of you who've supported me throughout this saga. I'm going to jury rig a couple of mufflers on it in the morning, then light it off again, set the timing closer to 10 BTDC and the idle around 650-700 rpm, then run it in at around 2000-2400 rpm for 20 minutes or so. Once that's done and nothing has gone to hell I'll drain the oil, replace the filter and turn my attention to setting up the AOD.
    It's been 51 years, gentlemen, but I've persevered to the point that it's a running hotrod. Don't know if I'll sleep soundly tonight or be so jazzed up that I won't sleep at all, but man, is it worth it!
  6. RodStRace
    RodStRace
    If possible, have a second set of eyes with you.
    Also make sure the trans has enough fluid pretty soon into that 20 minutes.
    Initial timing isn't as important as timing at cruise, so go for 28-32 BTDC up at that 2000-2400 RPM especially during that break in. It will not care what base timing is during that time because it won't be at idle.
    Fresh engines tend to run hotter, so have a contingency plan to keep it cool.
    Algoma56, saltflats, ClayMart and 2 others like this.
  7. I'm glad you reminded me of these things. I'd thought about putting a fan directly in front of the radiator, as I have my doubts that the little 13-inch fan sitting low on the radiator will pull enough air through to keep the engine cool once it heats up, and you know it will as fresh as it is at break in. Having some more ATF on hand is another tip I hadn't considered. I also need to install a radiator overflow can, now that you mention it. I'd better get the vacuum line to the distributor hooked up, too, considering I'll be running it at cruising speed during break in. Having it finally start up is great validation of all I've done to get to this point, but your reminders sober me up and alert me that I've still got a long way to go. Thanks again, Rod, for having my back.
  8. RodStRace
    RodStRace
    You got it! The vacuum can be plugged off for this. It just adds another thing to consider.
    Leave the battery cable untightened for quick disconnect, a hose would be nice, and a fire extinguisher!
    Hope for the best, plan for the worst.
    vtx1800, RICH B, Algoma56 and 2 others like this.
  9. Sharpone
    Sharpone
    Glad everything is coming together for you! I second get it running at 2000 to 2400 rpm as quickly as possible let run for 20 minutes min. I don’t shut them down unless something is way off like major leaks, too hot, low oil pressure. Like Rod said I adjust the timing for 30 32 degrees after I get it started. I let the engine cool off then start again and set timing to where I want, then set idle and adjust the carb. I love it when a plan comes together.
    keep us posted
    Thanks
    Dan
  10. saltflats
    saltflats
    from Missouri
    That's good that it went to a high RPM on first hit. Make sure it does that the next time if it has a flat tappet cam and keep it up there for the duration. So make sure sure you have enough fuel and a garden hose to spray the radiator to cool it down if needed. That transmission may hold close to a case of fluid depending on converter size, make sure it's full.
  11. Ziggster
    Ziggster
    Great news! Having just recently fired up my flathead for the first time a few weeks ago, I second having a second set of eyes there. “Stupid” things like checking oil pressure I forgot in all the excitement. lol! Suggest a checklist. I even bought new fire extinguishers for the “just in case” situation. I had overheating issues almost immediately. Had to shut her down after only 5 mins of running. So, make sure coolant level is good. Make sure coolant fan works. I even had a vacuum gauge hooked up that I forgot to check. Haha!
    I’ve had to do my cam break-in in 4 steps due to overheating. Still have the last 5-6 mins to do. When Nick from Nick’s Garage breaks in the cam/engine he does it in two 10 min sections. I think this is the best approach. Especially for novices. Gives time to check for leaks, etc. Evaluate what is going right and what is not right, etc. He’s literally built and dynoed hundreds of engines, and it’s surprising all the issues they run into on the dyno. Good luck!
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    Having a working vacuum advance will help the engine to not overheat .
    saltflats, Sharpone and osage orange like this.
  13. Spotty results Sunday. Ran long enough to heat up the headers and set off enough smoke from a left valve cover leak that I shut it down. Cleaned up and tightened up as best I could. Wasted hours trying to restart. In hindsight, probably flooded the cylinders. Worked to ensure the timing was right. Timing light says so, and that's re***uring but it still wouldn't light up consistently. Also, when it did run, the tachometer wasn't working.
    I'm subs***ute teaching Monday and heading in the direction of Atch and Saltflats Thursday afternoon and evening to take our son out to dinner a day after he turns 31. In between, I'll pull a plug or two and see if they're soaked, blackened or what they tell me. Someday this project will run consistently. Until then, Groundhog Day.
    saltflats likes this.
  14. saltflats
    saltflats
    from Missouri
    Sorry to hear of all the trouble this thing has caused you.
    Maybe I should look into a trip over and see if I could lend a hand.
  15. That's an extremely generous offer, James. Let's see what else I can accomplish this week. I'm going to start from the beginning, pull the plug on number one cylinder and confirm TDC, maybe pull that left valve cover and seal the oil weep, check the points gap now that it's had a couple of days of sporadic operation. If I can get it running again I'll adjust the carburetor so that it's not roaring to life and screaming like a banshee. I know I'm getting close.
    Sharpone and saltflats like this.
  16. Uncle Lee
    Uncle Lee
    I always thought that ford went out of their way just to be different. Best decision I ever saw them make was to study the Chevy big block and came up with the 385 series ( think I got the number right)
  17. It started right up this morning and I forced the accelerator linkage to bring the engine down to a fast idle, so that's one issue I'll need to address - stronger spring or something's hanging up in the linkage. The driver's side header is still smoking from the valve cover oil leak, so that's the second issue that must be addressed before another start up. While I let the engine cool down I wrestled with my tractor and brush hog for two hours, trying to loosen the pto shaft to the brush hog. Got it, mowed for another two hours, now I'm too tired to wrestle with the valve cover so I'll tackle it tomorrow. Tachometer still isn't registering. I've got a 50-year-old dwell meter that I think still works and I'll hook that up (it switches over to tach). Grinding forward, identifying one gremlin after another.
  18. I FIGURED IT OUT!!
    It was timing and a carburetor issue. First, the timing. When I put this 351W together, I opted for a p***enger-side discharge water pump so that I could get a radiator that also is used for sbc. The radiators were about $100 cheaper, but that opened up three other issues that I had to solve because of my cheapness. First, I had to make a new bracket for the alternator so that it would align with the crank. I had to also find the right water pump pulley to align with the crank. Of course that cost more than what I would save on the cheaper radiator. Duh. Then I realized that the new water pump would interfere with my ability to view the TDC mark on the crank pulley so I made a new one on the driver's side where it would be easy to see and light up with the timing light. The one-inch-wide timing finger that points to the TDC (I also marked 10 degrees BTDC) is precisely where it is supposed to be, but I forgot which side of that little pointer aligns correctly. Could be on the upper or lower side. Now I've got to go under the engine with a mirror, find the original mark, get it to TDC and see where the new marker lands. Doable, just a pain in the ***.
    The only good news: I'm close to having the timing right as it runs when it gets fuel, but just isn't right.
    Second, the carburetor. It is a Holley 4160 single pumper 600 CFM but an odd one because it has no float adjustment like most Holleys, and no sight hole in the side of the bowels to determine float level. It is some sort of oddball replacement for an Autolite carburetor out of the early '70s and that's about all I know about it. I got it at a garage sale. My cheapness again biting me in the ***. I took it apart, rebuilt it as best I could but now I'm convinced that I've either mis-***embled it or there's something plugging it up somewhere. It will pump fuel but not like it should. I'd already found out that I put the accelerator pump in upside down and corrected that, but it isn't working consistently. I'm either going to take it to someone for a second rebuild/look over or get another used 4160 carburetor with the float adjustment and sight hole. I know it's the carburetor because if I dribble gas into the carburetor, it fires up and runs for a second or two. Oh, and I'll need to vent the gas cap as running the engine for a few seconds also creates a strong vacuum in the tank that cuts off fuel flow.
    More good news. The valve cover oil leak was caused by too long machine screws bottoming out before they pulled the valve covers tight onto the cylinder head. Shorter machine screws and adding split washers solved that issue.
    Fellow HAMBers, thanks for your support and insight. To paraphrase Pogo, I have identified the enemy and he is me.
    vtx1800, RICH B, G-son and 3 others like this.
  19. ClayMart
    ClayMart
    Anybody that can quote from Pogo will be able to get this sorted out.
    :D
    patsurf and osage orange like this.
  20. RodStRace
    RodStRace
    Get a good carb. I wouldn't doubt that's an economiser that has the mixture screws 'backwards' too. Ugh. You were really shooting yourself in the foot with that and the ignition!
    All american V8s and most other engines rotate clockwise when looking at the front of the engine/pulley.
    If you marked 0 and 10 BTDC, on the pointer, the 0 should be the most clockwise and the 10 BTDC should be roughly 1/2 inch counter-clockwise. If you marked the pulley, it's opposite.
    If you are going to dive in and figure it out, round off the unused side or cut it to a point.
    Once the poor thing is broke in and idling, check manifold vacuum and use that to adjust timing. If it pings or is hard to start hot (kicks back) back off the timing. An exact number is nice and can be checked, but each combo will want a bit different tuning.
    To start and run an engine for 2 minutes, it shouldn't take more than a tables**** of fuel. If the tank is developing vacuum from that small of a change, it's either tiny and full or something else is happening. you can just unscrew it and perhaps tuck something in to keep it from fully sealing. Just like a Big Gulp, it doesn't take much of an opening to allow you to pull the liquid out.
  21. So now it's down to carburetion. Got the timing confirmed at 10 degrees BTDC + or -, which is factory spec. While I was down under the truck I noticed that the oil pan had oil leaking, so I tightened down those bolts and checked everything else I could. Many were not even hand tight, yet I remember being meticulous about torquing everything down to spec during ***embly. I guess heating up the engine the first time changes stuff. I should know that by now. Anyway, leaks have been stopped as much as I can see.
    Now to the fuel issue. Many times, the engine will start up and run for a few seconds when left overnight. It will run if I drizzle gasoline down the carburetor. I pulled the fuel line just before the carburetor and it spilled a teas**** of fuel from the carburetor side. I lowered the fuel line enough to confirm there was fuel from the pump to the hose going into the carburetor, and spinning the starter with the hose off sent fuel out of the hose so not a pump failure or obstruction from the tank to the carburetor. I pulled the carburetor and took off the primary bowl. No fuel spilled out. Did the same for the secondary bowl with the same results. I think that's evidence that there is an obstruction before the bowls, before the connecting pipe. I changed out the needles and seats while I was in there, but that's not where the problem is. It's got to be an obstruction in the primary metering block. I don't have access to an ultrasonic tub so I'm thinking I'll just get a new carburetor and be done with it. Damn! Just not in the budget at the moment.
    I still have some wiring to finish - cab marker lights and emergency flasher to the tail lights . Also need to hook up the emergency brake, shift the lower radiator hose away from the fan belt (it rubs), install seatbelts and dozens of other things while I put back some $$ for that carburetor.
    Sharpone and RodStRace like this.
  22. It wasn't the carburetor after all. I started a methodical diagnosis from the carburetor on back. The engine started and ran for a few seconds as long as I filled the breather tubes with gasoline, which filled the front and back bowels. Then I checked to see if the mechanical pump was pushing fuel. I'd checked that at the beginning of my attempted startup a couple of months ago and saw that there was fuel trickling out just above the pump, so "apparently" no restriction there. I did the same test Wednesday - starting the engine with the fuel line pulled from the carburetor and aimed into a tin can to catch fuel when pumped. Nothing doing. Could be the fuel pump itself, but I could see it was pushing air, just not fuel.
    I drained the 4 gallons out of the fuel tank and pulled the pickup tube and float gauge sender ***embly. I blew into the pickup tube and found it blocked. I suspect that in the days before I had finished plumbing the fuel line from the tank to the pump, I'd left the pickup tube open to mud dobbers or other wasps. Once I cleared the pickup tube with a piece of string trimmer line and a stiff wire, it was clear. I re-***embled it all, put it back in the tank carefully, put in about 8 gallons of non-ethanol fuel and it started right up! My tachometer isn't working so I revved it up to what I think is 2,000+ rpm and began monitoring gauges: oil pressure 55 lbs and steady; engine temperature 195 and still rising. alternator charging at around 14 volts, fuel tank at below half; TEMPERATURE ZOOMING TO 220 degrees!!!!
    Then a POP and the lower radiator hose starts spewing water! SHUT IT DOWN IMMEDIATELY and spent the next hour cleaning up the mess. The 13-inch fan hardly pulls air through the radiator, sitting down at the lower third of the radiator. I'd put an electric house fan in front of the radiator to help cool it just in case, but that wasn't nearly enough to bring the engine temperature down. I put a pet**** in the top of the Edelbrock Performer manifold to vent air/steam and burp the system at startup, but that hasn't solved the overheating issue, either. I'm letting it cool down now and then will go at it again in an hour or so. I need to run it in for at least another 10-15 minutes at cruising rpm and sort out the heating problems soon.
    And of course there are little oil drips from around the oil pan that I'm hoping to solve in the meantime. At least it runs now. I take back half the things I've said about the carburetor (which was never really at fault), but I take back nothing I've said about that damned Duraspark II ignition.
    And to all of you who've patiently endured my struggles and bone-headed mistakes in bringing this engine to life, a big fist bump.
    vtx1800, saltflats, RICH B and 3 others like this.
  23. Wanderlust
    Wanderlust
    It’s never easy for real people in the real world, least I’ve never found it to be :) But little by little you’re going to get there
    Sharpone likes this.
  24. In running the engine until overheating, I discovered that the coolant (just water at this point of break in) was not getting into the radiator, which was cold when I put my hand on it both at the top and at the bottom. I swear I tested that thermostat before installing it, even remember it opening at around 180 degrees. I'm pretty sure that's the issue, so a call to my local NAPA and I'll pick a new one up when another part I ordered comes in.
    As for the oil leaks, once I break in the engine, I'll have to pull the oil pan, clean off the mating surfaces, form-a-gasket the front and back around the main cap seals and hope it doesn't leak after re-***embly. At least the coolant system isn't leaking, so after I fix the oil pan and change oil and filter, I'll drain the water and put in antifreeze to close it up for the winter.
  25. Those pumps also use a different timing cover, although most don't have a provision for a mechanical fuel pump.
  26. RodStRace
    RodStRace
    Algoma56, Sharpone and osage orange like this.
  27. I laughed myself to tears when I read this. Yeah, I deeply appreciate it when things go right. I believe in The 50 Percent Theory of Life. Google it and you'll see why I don't give up.
  28. saltflats
    saltflats
    from Missouri
    If you are getting a new thermostat I would take the old one and gut it so it will act like a restrictor that way on break in you never have to worry about a stuck thermostat.
  29. I'm thinking that's a very smart next move. Gut the old thermostat, re-install it while I'm breaking in the engine, then save the 160-degree thermostat for later, once I know how warm the engine can sustain after run-in. Thanks for the guidance.
  30. saltflats
    saltflats
    from Missouri
    And ditch the box fan and have a garden hose with a spray attachment and use as needed.
