Front Air Ride spring issues
Discussion in 'The Hokey Ass Message Board' started by 427v8, Jan 20, 2008.
  1. http://www.airride.com/productinfo/dimensions.asp<TABLE cl***=AppTable cellSpacing=2 cellPadding=2 width=558 border=0><TBODY><TR align=middle bgColor=lightgrey><TH scope=col width=43> Part#</TH><TH scope=col width=134>Type</TH><TH scope=col width=59>Capacity @100ps</TH><TH scope=col width=68>Min.
    Height
    </TH><TH scope=col width=65>Installed Height</TH><TH scope=col width=50>Max. Height</TH><TH scope=col width=62>Diameter (inflated)</TH><TH scope=col width=59>Price</TH></TR></TBODY></TABLE>
    <TABLE cl***=AppTable cellSpacing=2 cellPadding=2 width=558 border=0><TBODY><TR bgColor=lightgrey><TD>
    F7076
    </TD><TD align=middle>rolling sleeve</TD><TD align=middle>800#</TD><TD align=middle>3.5"</TD><TD align=middle>5" - 6"</TD><TD align=middle>9"</TD><TD align=middle>4"</TD><TD align=middle>$65.00</TD></TR></TBODY></TABLE>
  2. dodgerodder
    dodgerodder
    This is bad news. Having the bags rub on anything WILL cause failure at some point. Real bad thing, especially when the frame drops to the ground on the highway when the bag fails. You could maybe try replacing the bags with Con***ech bags. They don't expand in diameter as they inflate, this might help
    Dan
  3. kustombuilder
    kustombuilder
    from Novi, MI
    have you concidered just talking to the guy you bought it from???
  4. 427v8
    427v8
    from Minnesota
    I dont get it. the dimensions are the same, 31" spring length, 36" perches...
    Whats wrong with mine?
  5. Unkl Ian
    Unkl Ian
    Echo
    Echo
    Echo
    Echo
  6. 427 Is it possible that your spring arms are shorter? I Checked out the dia. of the bags, 6'' inflated the cross member measures 6 9/16'' outside ,the plate it is made from is 3/16'' leaves 3/32'' clearence. I like the way it works but I plan on increasing the clearence for the bags.I will get the measurement of my arms later.
  7. 427v8
    427v8
    from Minnesota
    Fixed it. Got 6 inches of travel!!!
    I put shims in the adjustable perches effectively lengthening the arms by 1/2". Notice the better shackle angle.
    I think it should still be a little longer, maybe 3/8" and get even more travel.
