1952-59 Ford Front brake conversion, complete
Discussion in 'Off Topic Hot Rods & Customs' started by MJW, Sep 30, 2021.
  1. MJW
    MJW
    from NJ
    I just finished installing a Wilwood front disc conversion kit and also the Wilwood mustang master cylinder kit with proportioning valve.
    I bought it right after I got it in March as it was on sale and I knew I was going to do it eventually. This was sooner than expected but I needed new rims as the front driver had loose lug nuts that wallowed out the holes and ruined the studs also they are rusty chrome and didn't like them. I also needed tires as they were from 2012 and cheap imports.
    Definitely worth it. Very easy to install as its a very high quality kit and includes everything you need plus wheel spacers if you need them.
    It brakes so much better and with the new wheels and tires it tracks better too.
    The engine compartment will get detailed when I do the steering box that is waiting to go in and ceramic coated and polished exhaust manifolds at the same time.
    If you have any specific questions ask away.
    Here are some photos.
    PXL_20210918_151327938.jpg PXL_20210918_152012296.jpg PXL_20210918_154452314.jpg PXL_20210918_175921832.jpg PXL_20210925_135151191.jpg PXL_20210925_135330869.jpg
  2. frnkeore
    frnkeore
    Does it increase the track width?
  3. Slicks
    Slicks
    from denison tx
    Look's good
    MJW likes this.
  4. jimmy six
    jimmy six
    They are great and I sure like mine. I’m glad it went ez as mine did too.
    I started checking the temp of the MC and didn’t like it even tho I know the fluid is ok. Prestige Thunderbird in SanteFeSprings Ca has a longer heat deflector because the birds MC is even closer. I added a piece of silver heat reflecting insulation tape I bought from Home Depot after I painted it BBQ black. I also added a side one for the prop valve I don’t know if they are needed or not.
    Funny observation: the spindle brackets are made so you can mount the calipers to the front or rear. I chose rear. The spacers were not needed on mine either and are sure high quality.
    56longroof likes this.
  5. MJW
    MJW
    from NJ
    No it uses the stock spindles. I did use one of the provided 2.5mm spacers, they include 4, as I felt the wheels were a little too close to the original wheels.
  6. MJW
    MJW
    from NJ
    I too am thinking about heat shields but wanted to wait until I was done with the shake down to check for leaks.
    I may move mine to the rear as the elbow for the line at the caliper hits the sway bar end link and pushes it about an eighth of an inch at full lock.
    I used one spacer because the OG wheels are really close to the calipers.
    jimmy six likes this.
  7. jax59
    jax59
    from East Bay
    Cool man, got mine in now just gotta run some lines, how did you guys set up your brake light switch???
    MJW likes this.
  8. MJW
    MJW
    from NJ
    The proportioning valve came with the switch installed. Just needed to change my original bullet type to the female spade connector on the wires
  9. jimmy six
    jimmy six
    I took off the original one and installed where a plug was. If I just barely use my brakes to stop the brake lights don’t come on. I’m thinking of installing a switch on the pedal.
  10. jax59
    jax59
    from East Bay
  11. jax59
    jax59
    from East Bay
    Thanks guys, sounds like with the new brakes I won’t have to start braking three blocks before the stoplights any more
  12. jax59
    jax59
    from East Bay
    Hey MJW, FYI I just finished the Borgensen power steering set up for our cars……. A little more work than anticipated. Any way you said in your post you are gonna change over to power steering let me know if ya got any ?’s
    J59
    MJW likes this.
  13. MJW
    MJW
    from NJ
    Thanks for the offer, I'm planning on doing an electric one first and then if I don't like it I will try the Borgensen.
    I got a rebuilt Tbird box on the cheap. It also uses a two piece steering shaft with a splined coupler so there will be some fab work to use the original column. This is probably a few years down the road as the manual steering with skinny radials is not to bad.
    PXL_20210603_212320577.jpg PXL_20210603_212326761.jpg .
  14. MJW
    MJW
    from NJ
    My '68 mustang had the switch mounted on the pedal arm and was adjustable. I used the same setup on my Model A roadster as I kept the original mechanical brakes and the original style switch was really a pain to adjust.
    The pressure switches can be real hit or miss on quality. The one that came with the kit comes on even if I just rest my foot on the pedal.
  15. 53vicky
    53vicky
    Very nice. I did the same set up. Absolutely worth it.
  16. orangedog
    orangedog
    This is on my wish list down the road. Did any of you have a dual master cylinder before the disk up grade?
  17. Paul2748
    Paul2748
    On my 54, I fabbed up a bracket for a manual switch mounted on the dash to firewall brace. 55 ad 56 should be the same. I have a write up on it if interested.
  18. jimmy six
    jimmy six
    I like the old GM pickups with a lever actuator off the pedal under the truck. Should be ez under the dash too.,
  19. Fairlane 62
    Fairlane 62
    I converted my 54 to the lever type switch, and I used the plunger type switch on my 58 and 62. The newer pressure actuated switches don't seem to be as consistent as the old ones.
  20. Dos Cincos
    Dos Cincos
    It isn't pretty but it works. Just a piece of angle iron with a hole drilled in it and then welded to the firewall brace as mentioned above.
    evintho and nosford like this.
  21. JeffB2
    JeffB2
    from Phoenix,AZ
    Yes, I converted to a Bendix Dual master like this one it came from a Jeep Cherokee notice it is an aluminum casting and I polished it. I also rebuilt the drum brakes with new wheel cylinders and hardware. https://www.ebay.com/itm/265264136615 1967-Mustang-289-Engine-Specs.jpg
    nosford likes this.
  22. orangedog
    orangedog
    Thanks Jeff, my brake system was upgraded by the previous owner, master, wheel cylinders and lines. I will install the mustang rear adjusters, if they aren't done when I do the front disk. Did you mount your proportioning valve down on the frame? Buy the way nice polishing job on the MC.
  23. JeffB2
    JeffB2
    from Phoenix,AZ
    Since it is all drum brakes no prop valve was used.
  24. evintho
    evintho
    I did the same as Dos Cincos. Welded a bracket to the brake pedal support and another plate off the pedal. Mine is mounted a bit off to the side.
  25. Paul2748
    Paul2748
    Pic of the one I fabbed
    MJW and jimmy six like this.
