Technical Front brakes, early ford.
Discussion in 'Traditional Hot Rods' started by jscott1, Apr 10, 2018.
  1. jscott1
    jscott1
    What are the differences in 38,39 and 40 drum brakes?
  2. Bruce Lancaster
    Bruce Lancaster
    '38 and 9 use the wide 5 drum, '40 the normal 5 1/2X5.
    '38 use cable brakes, '39-40 use the same hydraulic brake.
  3. jscott1
    jscott1
    Thanks. I guss I have 39s. Wide fives and hydraulic.
    Will 40 drums fit 39s
  4. The '40 drums will go right on the '39 backing plates.
    Charlie Stephens
  5. Sutton Speed
    Sutton Speed
    If you decide you want to run '40 drums and want to part with your '39 wide 5 juice brake drums I would be interested in them. Thanks.
  6. 19Fordy
    19Fordy
    Stock 40 brakes are 1 3/4 in. wide. MT Products makes a complete kit to upgrade to 2 in. wide Bendix brakes design which provide better braking than the stock 40 Lockheed design brakes.
    http://www.mtcarproducts.com/Brakes.html
