Front Clip for '50 Chevy
Discussion in 'The Hokey Ass Message Board' started by BZNSRAT, Jun 6, 2007.
  1. BZNSRAT
    BZNSRAT
    Who has put a front clip on a '50 Chevy? What will match up...Camaro, Nova, etc??? Any tips?
    After calling about replacement bearings in front, I am seeing the reality that front clip will give me much more bang for the buck.
    Thanks
  2. Thommyknocker
    Thommyknocker
    from Colorado
  3. Honestly can't remember who makes it, but since the factory crossmember unbolts with relative ease, I would recommend a bolt in mustang II cross member. I would start by looking at fat man fabrication.
    I know they make them for the early IFS pickups, pretty sure they make them for 49-54 chebby's also.
    Good Luck...
  4. 49ratfink
    49ratfink
    mustang II. that's all I got to say
  5. 49ratfink
    49ratfink
    ch***is engineering makes the bolt in, there are several other companies making weld in.
    FATMAN FABRICATIONS makes one 2" lower than everynone else, and stainless tubular A-arms
  6. Mustang II...unless you are a glutton for punishment.
  7. BZNSRAT
    BZNSRAT
    I like the idea of a donor car sub-frame because of all the goodies you get with it for a fraction of the cost. I need a new column, wiring harness, front brakes, etc anyway...My Dad did his 47 pick-up w/ a Camaro clip and it has worked out great.
    Thanks Thommyknocker for the links to the info and thanks to rest of yall about the Mustang II stuff, I am sure it is the way to go, but economically I may have to go the front clip route.
  8. PeteFromTexas
    PeteFromTexas
    There Is No Reason To Do The Whole Clip... Ch***is Eng. Has A Bolt In Mustang Ii Kit. I Think It Has The Motor Mounts Installed So If Your Doing An Engine Swap It Will Be Easy.
    There Are Tone Of Other Kits Out There As Well
    Try 50chevy.com
  9. chop50chevy
    chop50chevy
    from upstate ny
    I used the Ch***is Engineering MII set up. I am very happy with it as far as installing it. Hopefully, in another year or so, I can tell you how happy I am driving it! Budget constraints are slowing me down at times, but I don't think I will regret spending the money on what I consider to be the backbone of the car.
  10. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    We put a camaro clip in my buddies 50 ford pickup. Used the camaro master cylinder, steering column, pedal ***embly, power steering etc.... The only thing we had to buy was two borgensen u-joints and some DD shaft. I like the way it drives way better than the Mustang II I have in my 38 chevy.
  11. Slide
    Slide
    Subframe will make your wheels stick out too far (unless you go with retarded looking shallow offset front wheel drive wheels). Subframes are cheaper when you think about it, but they get very expensive once you actually put them in.
    Subframes are awesome for some cars, but not 49-54 Chevys.
