1952-59 Ford Front Clip Removal
Discussion in 'Off Topic Hot Rods & Customs' started by frnkeore, Mar 18, 2021.
  1. frnkeore
    frnkeore
    Does anyone have a diagram of where the bolts are located, to remove the front clip, on a '54?
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. evintho
    evintho
    Jeff just beat me! Basically, 2 bolts underneath each front fender attaching to the rocker panel, remove splash shields and there are 2 bolts each side bolting upwards to the firewall, 1 bolt w/spring attaching core support to frame, 2 bolts each side connecting tops of fenders to firewall....I think that's it! I just removed each piece as I went along.
    JeffB2 likes this.
  5. frnkeore
    frnkeore
    Jeff, thanks for the parts pictures
    Evintho, thank you.
    I went out and looked, I found those bolts but, I found another, back behind the air duct/hood hinge, does that one have to come out? It's a little hard to get at.
  6. 54vicky
    54vicky
    if you remove the kick panel you can access the one mid way up fender
  7. evintho
    evintho
    What he said^^^. I forgot about that one!
  8. Kustomline54
    Kustomline54
    Horrible pic, but got mine out with an extension once the kick panel is out of the way. Bolt half way up on the fender by the door hinge
