1952-59 Ford Front crossmember
Discussion in 'Off Topic Hot Rods & Customs' started by the-stig, Dec 9, 2024.
  1. the-stig
    the-stig
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Shipping may be higher, he is in Canada.
  3. bondojunkie
    bondojunkie
    Looks like a nice unit.
  4. Bleach
    Bleach
    I’m glad mine is good.
  5. ottersea
    ottersea
    Mine is repaired. Question would you have a drain hole in the bottom or not?
    danman55 likes this.
  6. Bleach
    Bleach
    Yes, mine has a drain hole from what I remember.
    JeffB2 likes this.
  7. Okay, serious question here. I replaced my front crossmember in my 56 back in 2009. I found an amazing repro crossmember out of BC. Fast forward to now, I have a 56 Meteor parts car that spent 50+ years on it's side, and has a great crossmember and frame. Is it logical to think someone may want the crossmember out of it? I can understand saving the whole frame, but 99 percent of the time it's hardtops and Crowns and ragtops that people restore.
  8. Mark T
    Mark T
    Absolutely someone would be interested…
    Gas City Gearhead and JeffB2 like this.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Here is the Facebook source for 1955-56 Cross members Contact Ian Watt (905) 260-7403 He offers a discount if you include the top bracket from the old cross member. cookie.jpeg
  10. Texas57
    Texas57
    Not really related, but wasn't there a thread here a few years ago about a member who had a shop weld in a replacement crossmember. He was getting many negative somments about the weld job, some doubting it could not be made right or aligned correctly. Hopefully I'm remembering that much correctly. What ever happened to that thread/member?? Anybody know?
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    You can go back to almost day one in the archive threads, but since this group came into being in May of 2009 it may take you a long time to find it, sadly the search option here is pretty much worthless.
  12. 51504bat
    51504bat
    Sometimes if you Google what you're looking for and add HAMB to the search request you get better results than just using the HAMB search feature,
  13. Dos Cincos
    Dos Cincos
    This one?
    https://www.jalopyjournal.com/forum/threads/56-fairlane-frame-question.1307575/#post-15103477
    JeffB2 likes this.
  14. ottersea
    ottersea
    Wow. That is some job. Wonder if he got it back together again.
    JeffB2 likes this.
  15. Texas57
    Texas57
    JeffB2 likes this.
  16. beachcruzer
    beachcruzer
    I replaced mine with one of the last original (Goodall?) several years back. Braced and welded 1 inch angle iron to keep everything in place(Bare frame made all this much easier) Recorded several measurement points Cut off the bad one by using a 4 inch grinder on the welds, finishing some with a dremel tool, so as not to destroy the metal itself, leaving an easily visible line to set the new one in, checked my measuring points. Took a Margarita break, the day shouldn't be a total loss if I weld it in wrong.But it came out right on the money, verified about 8 months later by lazer process at frame shop With a qualified welder and careful prep,theres no reason this can't be done as well or better than factory
