Front end advice 28 on 32 rails
Discussion in 'The Hokey Ass Message Board' started by rustybucket, Jan 1, 2007.
  1. rustybucket
    rustybucket
    Looking for some guidance on my project. I’m building a traditional 28 roadster on duce rails with model a front cross member. I was wondering if anyone had advice on what front-end hardware to use? As far as wishbones, springs and axles are concerned what works and what doesn’t work both visually and mechanically? Right now I have an f100 box and a Model A axle, which I’m not committed to using. I plan on running a 3’ drop on the axle. As always I tried to search the topic if I missed a thread sorry for asking repeat questions.
    Any advice would be appreciated.
    Thanks
    Chris
  2. tysond
    tysond
    I'm interested in this to. I'm doing the same as you. I've got a 36 axle and wishbone. But I think I need 32 bones. Some one who knows will clear it up...hopefully.
  3. 5wbomber
    5wbomber
    The 32 bones are the best and the 32-36 axles is the best as for dropping,model A axle is next in line. Ill drop em for you!:D
  4. tysond
    tysond
    It's a bit far for me to ship to you. But I'll take a set of 32 bones if you're offering :D
  5. SUHRsc
    SUHRsc
    i think the f-100 box isn't the best choice
    the f-1 (48-52) is better looking with the pitman arm thats not so obtrusive
    really if your going for the earlier 40's look you should stick with the 32-34 steering or run 35-48 crossteering
    you can run the pitman arm up on a cross steer box and it looks pretty nice like loudpedal did on his 30 roadster he recently built
    as for the axle....a 32-36 axle would be best as it has a bit of drop in it already i think 1.5" compared to the A
    maybe with a reversed eye spring and a leaf or 2 out you wouldnt need to drop it to get the height you want
    i have a dropped 32 axle on my car with a stock spring with 3 extra leaves...i think mine is defeating the purpose of the dropped axle
    i didnt like how low it sat so i kept adding leaves till i liked it
    now i think i may go to undropped and reversed spring like i said
    im pretty sure it wont change the height of the car
    but it will add a little more caster and raise the clearance in the front so i can use a cherry picker to pull the motor wihout having it up on jack stands
    the 32 wishbone is the best to use if you have the stock wheel base
    i stretched my wheelbase 1 rivet hole in the front (1.25") and stretched the K-member also to accomidate it
    if your changing the wheelbase you can use a 33/34 wishbone and make that longer also
    split wishbones are also an option
    anything 32-41 would be good...the dipped 42-48 bones weren't really used that much that i see in books...so i would stay away from them on an average traditional car
    good luck
    Zach
  6. rustybucket
    rustybucket
    Thanks allot for the advice. I was thinking about running un-split 32 wishbones with a 32-36 axle. Are there any clearance issues with the oil pan or steering box when using un-split bones? Was there a difference between the V8 and 4cyl bones? When you use a reversed eye spring does it afect how the bones attach in the K member?
    Zach how much is your axle dropped?
    Does anyone have a good 32 wishbone or 32 axle they want to sell?
    Finally I’m not absolutely positive I have a F100 box what is the difference between F1 and F100? Is there a part number?
    Chris
  7. fab32
    fab32
    EVERONE should have the book by Mike Bishop (av8 on the HAMB) and Vern Tardel , HOW TO BUILD A TRADITIONAL FORD HOT ROD. The answer to all of your questions and a lot more is contained in this treasure trove of information. Nowhere else will you find the old time, tried and true methods and parts recomendations than this book. Buy it , READ it, read it again, and keep it handy while your building. I've got two copies, one for the shop and one for the library (you know where I mean:cool:)
    Frank
  8. rustybucket
    rustybucket
    Frank
    I agree with you totally. I have had a copy for 6 years and read it at least 20 times. That book is with ought a doubt pure gold. The only problem is it focuses mainly on a Model A framed ride. It does cover Duce applications but nut in as much detail.
    Thanks
    Chris
  9. SUHRsc
    SUHRsc
