Front End Detailed Breakdown!
Discussion in 'The Hokey Ass Message Board' started by BanjoBoy, Jan 8, 2009.
  1. BanjoBoy
    BanjoBoy
    Interested in seeing exactly what group of Original Henry Ford Parts everyone has used on Your Hot Rods. I mean detailed breakdowns from Axle/Bones/Hubs/backing plates/spring/ etc...
    I'm building 1 31 A coupe and have already searched many posts.
    I've not run in to a detailed breakdown Post. Lets see whats out there.
    Mostly interested in Hot Rod Front Ends.
    Thanks to all that can contribute:
    Ratty!
    P.S. Dont let my screen name Fool you . I love traditional Hot Rods!
    Additionally, I rarely start threads, mostly lurk since most info is already on here!
  2. BanjoBoy
    BanjoBoy
  3. BanjoBoy
    BanjoBoy
  4. OK I'll play. 4" Ch***is Engineering axle.
    34 spring and perches.
    34 wishbones, split
    39 stub axles.
    39 hydraulic backing plates.
    47 drums.
    35 16" wires.
    P & J shocks.
    Speedway loop steering arm.
    Speedway flat stock tie rod arms.
  5. BanjoBoy
    BanjoBoy
    Thats what Im talking about dammit. Im really excited about this thread and hope most contribute. Could really help us younger guys out and save us from alot of hardship. Dont get me wrong, the hunt for parts is half the fun. The other half is the build.
    Thanks B***man!
  6. BanjoBoy
    BanjoBoy
  7. striper
    striper
    Let's see if I remember.
    28A frame
    '48 axle
    '48 wishbone (split)
    custom spring 7 leaves, reversed eye mounted between bones in original A crossmember
    '48 spindles with steering arms bent downward
    '48 brakes, drilled backing plates
    '64 Buick drums adapted to '48 brakes
    Superbell, slingshot upper steering arm
    Cowl / side steering
    Swapmeet hydraulic lever shocks
  8. manyolcars
    manyolcars
    search
    Its all on here already a million times
  9. gashog
    gashog
    Very traditional with mostly stock Ford parts:
    32 wishbone
    32-36 axle (undropped)
    35/36 spindles
    53-56 F250 backing plates
    75 F250 1 1/16" wheel cylinders
    53-56 F250 brake shoes
    Pre 46 inside the drum juice hubs (not wide 5 style)
    64 Le Sabre drums and brake hardware
    Posies reverse eye Model A spring
    PJ spring perches & lower batwing shock mounts
    48-52 F1 upper shock mounts
    48 Ford shocks (16 1/2" rest/19.5" ext/12" comp, 25 degrees; Monroe 31000/NAPA RR94008 gas charged)
    Hairpin steering arm
    Stock Model A draglink
    Stock Model A pitman arm
    35/36 Ford tie rod/ends
  10. Or go buy the Bishop/Tardell book HOW TO BUILD A TRADITIONAL FORD HOTROD.
  11. BanjoBoy
    BanjoBoy
    already own the book tman. just curious what combos hambers are running.
  12. BanjoBoy
    BanjoBoy
  13. tdoty
    tdoty
    Those must be some rare parts :p
    Tim D.
  14. Lucky667
    Lucky667
    from TX
    Have you typed 30 coupe in the search box at the top of the page? Have you read everything about every build? That has kept me busy for weeks & I'm not finished reading.
    Good Luck.
    Lucky667
  15. gashog
    gashog
    Doi, very rare :)
    How about "Pre 46 inside the drum juice hubs (not wide 5 style)"
  16. BanjoBoy
    BanjoBoy
    Good stuff here
  17. BanjoBoy
    BanjoBoy
  18. Heres my setup on my pickup.
    Stock 31 Ford axle
    Stock 31 Ford spring (minus afew leaves)
    Stock 31 Ford split wish bones
    49-54 Chevy car spindles
    Mustang II rotors
    GM metric calipers
    Plymouth wheels
    Speedway caliper brakets
